Old 07-05-2012, 03:47 PM   #1
Does Primer get old/stale
I just received my Sheetrock 1st coat primer. The buckets look old. They haven't been opened as all the seals are intact. But on the bucket it says rotate stock every 90 days. Any ideas on this. I haven't used it but I would like to know in advance. Thanks.
aigsrone is offline   Reply With Quote
Old 07-05-2012, 04:41 PM   #2
Matthewt1970's Avatar
Paint and Primer will eventually have the ingredients speperate and they will harden inside the can but it takes a long time for that to happen and even longer if the can has not been opened. Open them up and see if you can get a stir stick all the way to the bottom.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-05-2012, 08:10 PM   #3
sdsester's Avatar
They may fail for sure if they have been exposed to improper storage or temperature extremes. If you returned used paint, leftover in your roller tray for example, you may have introduced mold and things to the can which may take hold as it sits. For best results, use primer and paint within the lifetime and expiration date on the can.
sdsester is offline   Reply With Quote
Old 07-05-2012, 08:49 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
And good luck with that First Coat. I hear it is a winner!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 07-05-2012, 08:56 PM   #5
sdsester's Avatar
Sarcasm? I do not know the brand and never used it. Is it some product Sheetrock branded?
Old 07-05-2012, 08:57 PM   #6
This has been discussed in another thread..
Old 07-05-2012, 09:08 PM   #7
sdsester's Avatar
Found it. Thanks. OP, in case you want to read the posts...
Sheetrock First Coat Primer
Old 07-05-2012, 11:09 PM   #8
How can it fail? Please give examples.
I looked everywhere I can't find any manfacture date or expiration date, just it says "rotate every 90 days" in instructions.
Old 07-06-2012, 05:49 AM   #9
paper hanger and painter
chrisn's Avatar
Just take it back, it is no good for priming anyway
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 15 03-24-2011 11:20 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 12:48 PM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 07:29 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
