Does A Newly Skimcoated Ceiling Need Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 11-11-2009, 02:34 PM   #1
Question
Does a newly skimcoated ceiling need painting?
I just had a ceiling skimcoated to cover up some poor patches and repairs left by a previous homeowner. The contractor did a great looking job and used a brush to create a slight texture to the finish on the ceiling. He used standard joint compound. I was talking to him about my next steps for priming the ceiling and he told me it might not be necessary to even paint the ceiling at all. When dry, the finish would be just as bright white as a painted surface.
This sounded too good to be true. My question then.... Is it necessary to paint the textured surface to somehow seal it up and/or prevent crumbling, dust or flaking off of the joint compound later? Or am I really just wasting my time priming the textured ceiling and then painting it white for no visible change in the end?
clubjuggler is offline   Reply With Quote
Old 11-11-2009, 04:21 PM   #2
Remodeling Contractor
yes you need to paint it. the paint protects from UV rays and moisture in the air.
Old 11-11-2009, 04:41 PM   #3
Rewards Points: 1,010
A painted surface is also easier to clean, more resistant to dust, and a harder surface
Anti-wingnut is offline   Reply With Quote
Old 11-12-2009, 07:12 PM   #4
Too Short? Cut it Again!
And you should definitely prime it first!
Old 11-13-2009, 04:11 PM   #5
Drywall contractor
Rewards Points: 1,070
As a rule in new construction, textured ceilings are not painted. (It saves the builder money.) You CAN leave it as-is, but I would paint if it were mine.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-15-2009, 11:48 AM   #6
Are you saying that as a rule of thumb, that standard hopper fed knock-down textures as used on residential walls and ceilings, that the cielings are not painted? I have never seen that to be the case.
Old 11-15-2009, 01:02 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
They do it around here all the time.
Old 11-15-2009, 02:19 PM   #8
Drywall contractor
Acoustical spray (popcorn) and stipple are not painted, as a rule, around here. I've never seen knockdown used with the exception of a couple of modular homes I did the drywall repairs on after the two halves were fastened together. I would guess that was painted since what I did was not a color match for what came from the factory.
Old 11-16-2009, 10:41 AM   #9
The main reason for popcorn and some textured ceilings is to cut costs and speed production in basic spec new home construction. this is why they do not paint it. but here we are offering advice to DIY'ers that are normally not building a new spec home. So as mentioned... painting is not required, but has advantages. Priming prior to texturing should always be done.
Old 11-16-2009, 10:47 AM   #10
If you read the OP, the ceiling was skim coated. That means it was covered by drywall mud, not a popcorn ceiling. Bare drywall mud should be painted
Old 11-16-2009, 10:52 AM   #11
Which is what I suggested to the OP>.. last comment was directed at your response to bjatlanta's comments. And to clarify the entire thread.
Old 11-16-2009, 10:56 AM   #12
I wasn't clear Bob, I was not directing my responce towards you. Bj brought up specious comments about popcorn textures, when with careful reading, one could discern that such comments were not applicable in this context.
Especially for someone who claims to be a drywall contractor
Old 11-16-2009, 10:59 AM   #13
Maybe I was being charitable when I said "with careful reading"
Old 11-16-2009, 05:02 PM   #14
Drywall contractor
Anti-wingnut,
The OP said the contractor "used a brush to create a texture in the mud". Sounds similar to the stipple I referred to where thinned "standard joint compound" is rolled on the ceiling and "blopped" with a brush. I never said "standard hopper fed knock down textures" should not be painted. I referred to acoustical spray and stipple, ONLY, in my second post for clarification. I also mentioned knock-down is not used in this area except for modular homes. In fact, I've never seen wall texture used at all except for a bar or restaurant around here. I also stated in my first post that I would paint it if it were mine. I'm a drywall contractor (I've probably forgotten more about drywall than you know), not a painting contractor. If the general contractor (or a homeowner) decides not to paint after texture, it's their call. Maybe you need to do a little more "careful reading"........
Old 11-20-2009, 03:09 AM   #15
Finisher
Whether texture or flat, ceilings should be painted, or at least primed. Raw mud will become brittle with time if untreated - and you will end up with bits of ceiling in your soup.
The longer you put it off, the more difficult it becomes to prime/paint - because once the mud goes brittle, backrolling (which evens the appearance of the topcoat) will peel the ceiling off in sheets. I've seen it happen before.
Rcon is offline   Reply With Quote
Painting a textured ceiling computerdude103 Painting 4 06-28-2009 11:43 AM
Painting at the ceiling edge webtekie Painting 5 09-30-2008 08:52 PM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 03:38 AM
popcorn ceiling painting phil334 Painting 2 07-11-2008 11:23 PM
