Does Linseed Oil Really Soften Hard Old Putty? - Painting - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 07:03 PM   #1
Rewards Points: 1,062
Does linseed oil really soften hard old putty?
trying to restore vintage window frames with gobs of putty stuffed on by incompetent minions of yesteryear. There are sections where the putty glazing is rock hard. Heat element could shatter the pane, I understand.
I heard linseed oil, boiled, and applied should soften it. Not sure if they meant to apply it whilst boiling.....LOL. Think this is effective?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 08-08-2012, 07:57 PM   #2
Hey noquacks. Is noquacks equivalent to quackless?
I doubt very much that anything will soften old glazing. I have used heat, open flame (but I'm not recommending that), without shattering glass by using a six inch spackle blade as a shield. One possible solution may be to use some coarse paper, 60 or so, and sand the high points down and skim coat the surface with new glazing. It's worth a shot before making the effort to remove glazing that doesn't want to be removed.
The Following User Says Thank You to jsheridan For This Useful Post:
noquacks (08-09-2012)
Old 08-08-2012, 08:06 PM   #3
Rewards Points: 12,790
I just use my heat gun, seems to just roll right off for me.
Old 08-09-2012, 04:19 PM   #4
Really? Just ROLL right off? never had glas crack? What kind of heat gun? 1000 watts? Im ready to try it if glass wont crack, joe. Thanks, Man.
Old 08-09-2012, 04:55 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
it wont
it will
chrisn is online now   Reply With Quote
Old 08-09-2012, 05:41 PM   #6
Originally Posted by chrisn View Post
it wont
it will
Geez- it will, it wont, it cant, it shant- Looks like this is not a consensus, people. I can appreciate that. I just want to understand my risks. Looks like theres no established method.
Old 08-09-2012, 07:19 PM   #7
Use a shield, the putty will not transfer heat. Heat will crack glass if you hit it directly. Going from ambient temp to 1000 degrees in a second will crack the glass.
Old 08-09-2012, 08:19 PM   #8
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Old 08-09-2012, 08:20 PM   #9
Stuck in the 70's
Around here lately there really hasn't been much difference between the outside temps and a heat gun!
Old 08-09-2012, 08:38 PM   #10
OK, so will this gun do the trick?
http://www.ebay.com/itm/NEW-1500W-Wa...omain_0&hash=i
Hotter? Colder?
Thnaks!!
Old 08-10-2012, 05:07 AM   #11
chrisn's Avatar
Rewards Points: 120
I have re glazed probably a thousand windows and have found that scrapers, chisels, razor knives, screw drivers, five in ones, etc( all sharp) are the way to remove old putty. If it is stuck tite, then it need not be removed
The Following User Says Thank You to chrisn For This Useful Post:
noquacks (08-10-2012)
Old 08-10-2012, 12:56 PM   #12
jschaben
Rewards Points: 502
I use a multi tool with a flexible scraper blade. Just make sure it isn't oscillating against the glass.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 08-10-2012, 04:50 PM   #13
Right, chrisn, its on rock hard, and otherwise I wouldnt remove it, but geez, its gobbed on sooooo ugly by minimum wage minions of yesteryear- not exactly what one would want to keep for a restoration job on vintage windows. Thats my dilema......
Old 08-10-2012, 05:35 PM   #14
chrisn's Avatar
Rewards Points: 120
Go to blowes and get a big olfa razor knife and trim is back, get extra blades
Old 08-10-2012, 09:31 PM   #15
Too Short? Cut it Again!
Please heed most comments. If you go at this with a heat source make sure to buy a good self-lubricating glass cutter! And save your pennies if you need to replace antique window glass.
Window Glazing question DIY DUDE Painting 29 05-28-2015 02:03 AM
faucet hard to pull out? Leprichon Plumbing 14 11-15-2014 01:11 PM
silicon vs. plumbing putty: does plumbing putty discolor cultured marble? lazzlazz Plumbing 6 05-12-2010 08:49 AM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 09:19 PM
Window putty won't dry - wet atmosphere DIYNovice0 Remodeling 14 02-23-2010 01:40 AM
