Old 06-29-2012, 09:12 PM   #1
Does Heat Accelerate the Curing of Paint
I have 1 panel that needs a cutout....
I plan to prime and paint this panel....knowing the the cabinetmaker will be back to make this cutout.
I don't want to paint knowing the paint will very well shred.chip when it makes the cutout.
However, does HEAT accelerate the curing process.
The cutout will be done via router on MDF.
If heat does accelerate the curing (hardening) I may potentially paint this panel and put it outdoors in the bright sun to bake...
Paint will be Aura Matte
mobiledynamics is offline   Reply With Quote
Old 06-29-2012, 09:30 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Sure- the sun will harden it up. So will moving air. Humidity will slow it down.
Kind of common sense, no?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-29-2012, 09:36 PM   #3
Ha. U tell me. There are some rooms in which I can tell the paint is not cured....you pros see this everyday. it's kinda like drywall. It has a different feel. There is a slight ~cold~ to noncured paint.and it does feel difference on the surface on cured paint . I'm just talking Aura though..
Old 06-29-2012, 09:46 PM   #4
Cured and dry to touch and dry to repaint are 3 different things.
But I bet if you read the can it would tell you what is what..
Old 06-29-2012, 09:49 PM   #5
I'm talking about 2 week old paint versus 4-5 week old dried Aura Matte.
Just saying...it has a different feel when you put your hand to them. I never A/B noticed them until now ....as I am painting alot of rooms at various stages
Old 06-29-2012, 09:56 PM   #6
Go read the can and write here what it says for full cure.
You can do it!
The Following User Says Thank You to Brushjockey For This Useful Post:
sdsester (06-30-2012)
Old 06-30-2012, 04:57 AM   #7
paper hanger and painter
chrisn's Avatar
aura is no different than any other paint for cure time
Old 06-30-2012, 06:32 AM   #8
Matthewt1970's Avatar
Thickness can play a factor.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-02-2012, 08:24 AM   #9
Virtually all chemical processes are sped up or slowed down by presence or absence of heat. That said, too much of either are bad. Better to put the piece in a low humidity/good airflow environment than bake it in the sun.
Paintguy is offline   Reply With Quote
Old 07-02-2012, 09:05 AM   #10
I ended up baking it..
It needs another coat of paint anyhow - so UV discolor was not a concern.
These were flush access panels that blend with the wall.
Cabinetmaker is going to take a router to it - and cut out the holes for the dials and such.
I painted it this weekend and knew the paint would shred if it was not *baked* as this stuff takes awhile for it to *dry* if not bond-bond to the surface. Baked it - just to minimize the shredding
Old 07-02-2012, 09:16 AM   #11
jschaben
Some depends on your cabinetmaker. If he uses a down spiral bit, most of any shredding would happen on the bottom side. Compression bit should leave almost none on either side.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-02-2012, 09:33 AM   #12
you're talking a whole nuther world I'm not familar with....don't know sch1tz on routers and how it cuts
Old 07-02-2012, 11:51 AM   #13
A good test for cure is to use a fingernail test to see if it leaves an indentaion. Most latex paints cure in 30-45 days. As previously stated, humidity and heat slows down this process.
Will22 is offline   Reply With Quote
Old 07-02-2012, 12:05 PM   #14
Yeah..I did not know how long these new formulations take...
In the midst of renov. and finishing. I leaned a solid slab door on one wall that was 2 weeks old....and when I leaned just the edge into the wall and lifted, I knew it was not cured....as it left a slight edge indent/paint lift on it.
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
