Does Drying Time Apply To Fresh Cedar? Prime First? - Painting - DIY Chatroom Home Improvement Forum
Old 06-17-2010, 10:17 AM   #1
Rewards Points: 256
Does drying time apply to fresh cedar? Prime first?
Building new stairs up to a porch, posts are cedar but remainder is PT lumber. I know the PT needs to "dry out" before I can paint it but does the same apply to cedar? Prime now, paint later? Both now? Both later? Thanks!
moneymgmt is offline   Reply With Quote
Old 06-17-2010, 11:54 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
no prime or paint immediately,actually back priming and priming all cuts is a good idea too
Tom Struble is offline   Reply With Quote
Old 06-17-2010, 11:58 AM   #3
Rewards Points: 256
Can you clarify this for me a bit? I am not familiar with the term "back priming", and by cuts I assume you mean all end grain?
Thanks for your help!
Old 06-17-2010, 12:06 PM   #4
back priming means just that applying a finish to the backside of the cedar
and ALL cuts should be primed before installation,you can get cedar pre primed
the most common reason for finish failure on cedar is letting the sun degrade the fibers and lignins on the surface of the wood,this can happen in as little as 2 weeks
i like to prime all sides and have 1 coat of finish on the wood before i install it,then 1 more coat of finish after installation
Old 06-17-2010, 02:40 PM   #5
Rewards Points: 256
does that apply to fresh/wet PT wood? Or are you speaking just to cedar?
Old 06-17-2010, 05:27 PM   #6
any type of wood for outside use should be protected imo
as far as the pt being wet,i would treat any cuts with at least a clear water repellent
a neat trick to try and figure out if pt is dry enough to take a finish is to sprinkle a few drops of water on it,if it readily absorbs it within 15 min its ready
The Following User Says Thank You to Tom Struble For This Useful Post:
Gary in WA (06-17-2010)
Old 06-17-2010, 08:34 PM   #7
Registered User
Rewards Points: 5,212
Tom's on the money.
Number 6: http://www.anthonyforest.com/pdfs/AW...mendations.pdf
How soon? http://www.wolman.com/faqs.asp?faq_id=31
How to clean p.t. wood: http://www.wolman.com/faqs.asp?faq_id=28
Why? http://www.wolman.com/faqs.asp?faq_id=2
Ok, getting to sound like an ad……
Similar: http://docs.google.com/viewer?a=v&q=...z8RuX3ucI3r11g
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Tom Struble (06-17-2010)
Old 06-17-2010, 09:26 PM   #8
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Any type of wood should be dried out before applying a coating. If you coat the wood and it contains to much moisture you will have coating failure issues, you really should use a moisture meter first to determine the moisture content, usually for most coatings a moisture content of 15% or less is suitable to apply your coating.
housepaintingny is offline   Reply With Quote
Old 06-17-2010, 10:48 PM   #9
very true house painting guy,but how it dries is more important,exposing unprotected wood to uv can damage the very wood fibers your trying to protect
Drying time and painting a front door gramps416 Painting 1 05-17-2010 12:01 PM
fresh sheetrock, prime? jamesdart Painting 3 02-25-2007 07:22 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
