Does Base Require A Tint For White? - Painting - DIY Chatroom Home Improvement Forum
Old 12-11-2013, 02:39 AM   #1
Rewards Points: 22
Does base require a tint for white?
I have acquired some white Benjamin Moore Concepts latex Base 3 R798 3X but it seems thin and runny and not too solid in body nor does it cover well. Does it need a white tint to cover properly? Is it compatible with other manufacturers tints or must I use BM's Gennex tinit?
Martik777 is offline   Reply With Quote
Old 12-11-2013, 05:46 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
That base is meant for dark colors. You'll have to add a lot of tint to make it useable. It'll likely dry clear if left untinted. White is not something you'll get from a base 3.
Darkling Designs
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
Jmayspaint (12-14-2013)
Old 12-14-2013, 11:07 AM   #3
Rewards Points: 4,796
I don't think you can use some other manufacturer tint and get a true BM color, but if you don't care a whole lot about the specific color, I doubt there's a lot that would go wrong by tinting it with generic tint. Might not be ideal.
If the paint is runny, adding tint won't help. Concepts paint is mediocre paint, more or less on par with Ben paint.
jeffnc is offline   Reply With Quote
Old 12-18-2013, 09:34 AM   #4
Rewards Points: 394
White colorant added to a deep tint base will not accomplish good coverage or consistent color, regardless if you use the BM colorant or another universal colorant. Generally, the white tint base in most lines (4 ounces short fill) is used for this purpose.
Will22 is offline   Reply With Quote
Post base for wood porch Quercus Building & Construction 2 07-22-2012 02:43 PM
Compacting wet/muddy soil for paver/wall base BrandonC_1972 Landscaping & Lawn Care 0 07-04-2012 10:34 PM
Base molding help...need ideas Lillbush555 Carpentry 9 09-19-2010 07:38 PM
Water coming in at base of foundation Ptron Building & Construction 22 08-09-2010 09:51 PM
how to nail base cap of baseboard molding conradA Flooring 3 06-23-2010 11:57 AM
