Does Applying Paint With A Roller Apply More Paint - Painting - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 08:24 PM   #1
Rewards Points: 260
Does applying paint with a roller apply more paint
This is for rough sawn (heavy texture) wood. I tried applying Duration exterior paint with a brush only and it seemed to go on thin. I guess I could just apply more paint, but I want the paint the same thickness and consistent. I was wondering if applying it with a roller and back brushing is a better method. I'm trying to just use a coat of primer and one coat of Duration. Also, what is the appropriate nap thickness for my application (1/2" or 3/4").
bluefitness is offline   Reply With Quote
Old 02-11-2009, 10:45 PM   #2
Rewards Points: 2,906
There's no right or wrong answer here.
I've actually been told that you get a thicker coat of paint with a brush than a roller, but I think a lot depends on the length of the nap on the roller sleeve you use, and how much you spread the paint.
I think your best bet would be to buy roller sleeves with varying nap and see which one works best for you.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-12-2009, 06:01 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
...I was wondering if applying it with a roller and back brushing is a better method.
Yes, it is
Hard to say for sure w/o seeing it, either should work
W/o hesitation I'd say 3/4 won't do you wrong if you are back-brushing
If I showed up at the job sight un-seen but with your description I'd have a 3/4 ready to go
slickshift is offline   Reply With Quote
Old 02-12-2009, 11:55 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
With a heavy texture you will want to use a roller. A brush will tend to want to fill the valleys in the wood with paint and mot put enough on the peaks. You will also be doing a lot more work with a brush trying to get it even.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
