Do They Make A Extra Long Roller? - Painting - DIY Chatroom Home Improvement Forum
Old 10-16-2007, 11:23 PM   #1
Ummmm...
Shpigford's Avatar
Do they make a extra long roller?
So it seems like most rollers are a standard wide of like 12-18". Do they make one that's like 24" or even 36"?
And if they don't...why not?
My naivety is making itself known here...but wouldn't a wider roller mean you paint more in less time?
Shpigford is offline   Reply With Quote
Old 10-17-2007, 05:53 AM   #2
Guest
Guest
Posts: n/a
Try picking up and rolling a wall with a fully loaded 36" roller. I'll give you two minutes before you put it down and say to hell with it. That's a lot of weight to hold up for an extended time. Also the wider the roller the harder it is to get an even coverage if your walls are not perfectly flat, and believe me they aren't.
Old 07-15-2011, 06:27 PM   #3
Too Short? Cut it Again!
A pro oriented paint supplier will have wider rollers and pans. As mentioned, they do get heavy when you load them with paint. You may find you do not like them so much. In all the years, I have seldom used them.
Old 07-15-2011, 08:12 PM   #4
Gymschu's Avatar
Rewards Points: 846
Amen to the weight problem.........once did a house with an 18" colossus roller. It did cover faster but the hand, arm, shoulder fatigue makes for some long days. Also difficult to get tight into corners. A 9" is plenty fast enough if you keep moving.........
Old 07-15-2011, 08:15 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
14" open end is my favorite size. But I need to get them online.
Brushjockey is offline   Reply With Quote
How do you use a loop roller? redline Painting 8 04-02-2013 09:05 AM
Do they make this? Malcolm Roofing/Siding 3 10-13-2007 11:23 PM
How much load can a 20' long 2x8 support? GrdLock Building & Construction 9 06-29-2007 11:15 AM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 07:01 PM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 12:37 PM
