Do Latex And Water Mix? - Painting - DIY Chatroom Home Improvement Forum
Old 11-27-2006, 08:15 PM   #1
Do latex and water mix?
From Lowes brush care suggestions:
First dip the brush in the solvent suggested by the manufacturer. This is done before painting to prevent paint dry-up on the bristles and for smooth application.
O.K.
In the case of an oil based I would know that solvent/thinner can be used this way. What about Latex? Is water the solvent in this case? During my last exterior job I did not try dipping the brush in water because I was not sure that this would be right and I did not want to find out on the front of the house.
Thanks alot
eric s is offline   Reply With Quote
Old 11-28-2006, 01:38 AM   #2
Pro Painter
AAPaint's Avatar
Yes, you would dip it into some water. Be aware that doing so can cause the paint to run down the handle easier if you're not careful. I would dip it, then kick/spin the excess water out.
As a general practice, I don't dip my brush in anything before painting, but it is cleaned frequently during use. I wouldn't consider this a critical step working with latex.
AAPaint is offline   Reply With Quote
Old 11-28-2006, 04:25 AM   #3
Pro Painter
Don't saturate the brush, I usually just get a little water on my hand and rub it onto the brush to make it damp, not wet. That way I don't have to abuse the brush, kicking, slapping and spinning.
joewho is offline   Reply With Quote
Best paint for kitchen? stash Painting 20 12-15-2011 12:47 PM
Embarrassingly stupid question about latex paint joeyboy Painting 7 08-20-2007 10:25 PM
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 10:29 PM
painting & prep-- Slickshift? sundog Painting 10 01-17-2007 08:32 AM
