Do I Really Need Special Primer For Masonry - Painting - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 11:56 PM   #1
Rewards Points: 1,062
Question
do i really need special primer for masonry
i need to paint no more than several sq ft of mortar patching around a window set in brick, for the looks. the dude at sherwin williams suggested i use LOXON masonry primer but they want $50 for a gallon can. my jaw dropped to the floor.
is this special primer for masonry really a needed distinction or is it just another commercial koolaid where you can get away with a basic/generic product?
thanks
Old 01-27-2012, 12:07 AM   #2
Rewards Points: 14,306
It's never a good idea to paint brick in the first place, want it to stick it's needs a bonding primer.
Old 01-27-2012, 12:34 AM   #3
but can i use regular primer that i can buy by quart instead of forking out $50 for a gallon here is my question
Old 01-27-2012, 05:51 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You can use a high quality acrylic primer like Zinsser 1-2-3, but make sure the patching is well cured if it's fresh.
Darkling Designs
poppameth is offline   Reply With Quote
Old 01-27-2012, 06:20 AM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Use the Loxon, as its designed for masonry surfaces. That's our go to masonry primer.
You don't need a bonding primer.
You don't want to use a primer unless its masonry specific.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
chrisn (01-27-2012)
Old 01-27-2012, 06:35 AM   #6
Ravenworks's Avatar
All you need is an "alkali resistant primer"
Ravenworks is offline   Reply With Quote
Old 01-27-2012, 07:20 AM   #7
Too Short? Cut it Again!
We are talking interior here? Right? Only seal masonry if you have to do so. Then use a proper masonry primer. Come on, $50/gallon is no more than 8 cups of Starbuck's coffee?
Old 01-27-2012, 07:22 AM   #8
BraniksPainting's Avatar
thanks
For one, there is no problems painting masonary. Masonary is a very porused surface and if done properly, you will never have an issue.
If you masonary is new, yes you should use the LOXON masonary primer. It is the absolute best product for your project. Hell, I even use it on new drywall. It may be overkill but I know my customer will never have any problems.
PLEASE, PLEASE, PLEASE do not use a generic product or skimp on this prime coat step. You will regret it down the road. It would be like putting a sink in but never connecting the drain.
BraniksPainting is offline   Reply With Quote
The Following User Says Thank You to BraniksPainting For This Useful Post:
amakarevic (01-27-2012)
Old 01-27-2012, 11:45 AM   #9
nope. exterior.
Old 01-27-2012, 12:17 PM   #10
Amakarevic, you can use Zinsser 123, and buy it in a quart. While Loxon is a quality, serious product, why buy a gallon of something for 50 buck to use what amounts to a pint. For the non-believers out there, from the TDS of 123:
"Resistant to high pH surfaces (up to 12.5) including; plaster, poured concrete, concrete block, stucco and ‘hot’ joint/texture compounds."
Good call Poppa
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
amakarevic (01-27-2012), ltd (01-28-2012)
Old 01-27-2012, 01:27 PM   #11
Mr. Paint's Avatar
I agree with the quart of 1-2-3 for a homeowner. It will be fine. I recommend Rapid Set Cement Products for patching as they do not create a pH issue.
Mr. Paint is offline   Reply With Quote
Old 01-27-2012, 06:44 PM   #12
Question
can you explain this? what kind of ph issue and how does it affect?
thanks
Old 01-27-2012, 09:57 PM   #13
Rewards Points: 616
Good call Poppa
Mortar, concrete, cement usually has a ph (acidic) level of about 12-13 and can sometimes be 14 or 15 initially. In my opinion, regardless of what the Loxon cost that would be what I would use and it is especially designed for masonry surfaces.
Old 01-28-2012, 06:28 AM   #14
I understand the points being made, and if I had a pro project of coating new masonry, I would use Loxon or a similar concrete primer. However, in OP's situation, I would use a secondary general purpose primer that is spec'd for use on concrete. I might even use it on a pro project given the little bit of work it's being called upon to do. Were it a large project versus touching up a small area, I would suggest Loxon. I just think buying a 50 dollar gallon of paint to use what amounts to a pint is overkill for an HO. I'll have future uses for it whereas OP probably won't. Loxon requires a seven day wait on new concrete and handles PH level up to 13.
Old 01-28-2012, 02:39 PM   #15
ARC Painting's Avatar
You could use Coronado's Aqua Stop-It. This is a paint designed to go directly on concrete.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Tags
primer
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
