Do I Need To Wait To Do A Second Coat? - Painting - DIY Chatroom Home Improvement Forum
Old 03-16-2009, 12:08 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Do I need to wait to do a second coat?
If the first coat of paint is dry to the touch, can I put on a 2nd coat, or do I have to wait 24 hours?
yummy mummy is offline   Reply With Quote
Old 03-16-2009, 12:17 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
what does the can say yummy? it usually dependent on temp and humidity
Tom Struble is offline   Reply With Quote
Old 03-16-2009, 09:10 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Dry to the touch is all you need for most paints yummy
The can should have a re-coat time on it
Probably between one and four hours
But generally, if you've got good temps and low humidity, you can push that quite a bit
If it's just barely dry to the touch, and still too early to re-coat, you'll know right away when applying the second coat
The new wet paint will activate the previous almost dry coat, lifting and pulling it, and generally turning into gookie globs
If that happens, just walk away, wait a while longer, fix and re-coat it later
High humidity, low temps, and deep colors (lots of slow-drying solvent based tints) can slow the drying time quite a bit
slickshift is offline   Reply With Quote
Old 03-16-2009, 09:27 AM   #4
The can says four hours, but I thought that maybe I could have speeded it up somewhat, but I will wait till the next day.
Thanks.
Old 03-16-2009, 06:07 PM   #5
Rewards Points: 27
24hrs. Most painters can't wait that long for a second coat. Time is money. But since you are painting for yourself and it seems you have a doubt about the drying time before the second coat then, the best thing to do is wait 24hrs. that way you don't have to worry about the temperature having much affect on the drying time or the second coat wetting the first coat again and streaking.
Determined is offline   Reply With Quote
Old 03-17-2009, 04:57 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Old 03-17-2009, 04:44 PM   #7
slickshift's Avatar
It's a technical term
...or it should be
Old 03-18-2009, 06:10 AM   #8
chrisn's Avatar
Rewards Points: 224
or it should be
I agree!
Old 03-19-2009, 09:13 AM   #9
i agree with you slickshift
Dana
Dana11 is offline   Reply With Quote
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
First coat on inside corner, need advise.. helpless handyman Building & Construction 6 09-24-2008 01:22 PM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
Round 2 & 2nd coat question usaalways Painting 5 06-24-2007 09:20 AM
