Do I Need To Sand? - Painting - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 11:39 AM   #1
Do I need to sand?
I have just painted my room a color that does not look great and want to re-paint it. Has been only a week since. It is the 3rd color on the wall (so about 7-9 coats), and it was not even from before and to be honest perfection is not necessary as it is already not perfect.
The question is: Do you HAVE to sand it now because of the number of coats? or just sanding it makes it more even and easier. or in other words, can i just paint my 4th color of the light color or will it cause problems like chipping. Im going slightly darker so would think its easier.
Thanks,
Craigmohr is offline   Reply With Quote
Old 03-27-2012, 12:11 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
You do not "HAVE" to sand, but you will want to at the very least do a quick sand of the walls. You will be surprised what was in the old layers of paint that a quick sanding will knock off.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 03-27-2012, 12:16 PM   #3
Matt is dead on. You dont have to sand but if you have the extra time go for it, it can only help. Make sure after the sanding to wipe down the walls with a damp cloth.
LarryThePainter is offline   Reply With Quote
The Following User Says Thank You to LarryThePainter For This Useful Post:
Mr. Paint (03-27-2012)
Old 03-27-2012, 01:02 PM   #4
Thanks guys...great help which i was looking for.
fine sand in cold water line, cold water stopping then turning hot and blasting sand cstrange Plumbing 2 12-02-2011 03:19 PM
finishing paver patio - what sand? H.O.P. Landscaping & Lawn Care 2 07-20-2011 03:00 PM
Need Help - Failed Patio in Sand Install lews Landscaping & Lawn Care 5 04-19-2010 07:34 AM
Best Way to Establish Plantings Over Sand flyboy Landscaping & Lawn Care 4 04-07-2009 10:38 AM
painting sand over sand heather Painting 1 04-03-2007 11:35 AM
