Old 07-13-2014, 10:24 AM   #1
Share |
Do I need to reprime
I primed (Behr latex primer) my drywall about 6 weeks ago, then found out that the paint I wanted to use (Ralph lauren suede) was not in stock. I finally received the paint and am reasy to paint - do I need to reprime? If so, do I simple apply the same regular primer over the existing primer or do I need to get a different primer (since it's going on top of existing primer)?
thx
cgott42 is offline   Reply With Quote
Old 07-13-2014, 11:24 AM   #2
cj133's Avatar
If it was me, I would make sure the walls are dust free and just paint them. No reason to prime again.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 07-13-2014, 12:58 PM   #3
Jmayspaint's Avatar
I wouldn't think you would need to prime again. Would be a good idea to sand the primer though, at this point the primer has reached full cure. It won't be as easy for the finish coat to bond well. Scuffing it up would help that.
Jmayspaint is online now   Reply With Quote
Old 07-13-2014, 01:40 PM   #4
Probably overkill but I would re-prime 6 weeks is quite awhile things could have been sprayed (hairspray, deodorizer, air freshener, ect.), spilled, rubbed against, and "I don't know what that is". And another coat of primer for insurance wouldn't be much more than sanding.
Old 07-13-2014, 02:08 PM   #5
Easy to reprime than sand.
Do I just apply another coat of primer directly on the existing one?
Old 07-13-2014, 04:45 PM   #6
paper hanger and painter
chrisn's Avatar
yes
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (07-13-2014)
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
