Do I Need A Primer? - Painting - DIY Chatroom Home Improvement Forum
Old 10-16-2013, 06:46 PM   #1
Do I Need a Primer?
We want to paint our kitchen walls a dark red/burgundy color to make it feel a little warmer. It was two rooms that the previous owner converted into one large kitchen area. The paint store advised us that we would need a primer because of the color, as well as two coats of the paint. Is it possible to skip the primer and just paint the two coats?
Panda2 is offline   Reply With Quote
Old 10-16-2013, 06:55 PM   #2
Rewards Points: 13,446
Depends, what color are the walls now?
#1, I'd never suggest anyone paint a kitchen a dark color. Make's it uninviting, and it will show every speck of dirt.
#2, If I did I for sure would use a primer tinted gray or one pretinted to at least 50 % of the color I was going for.
If not your going to be painting more then two coats anyway to get an even finish.
Old 10-16-2013, 07:08 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
It's possible. With a high end paint like Aura or Emerald, two coats of paint will cover with any color.
But even with these paints, it depends on the application. Aura paint advertises 'never more than two coats with any color'. But one 'application' doesn't always equal one 'coat' in terms of film thickness. In fact, it rarely ever does even for pros. So, you may have to paint the walls three or four times to get 'two coats' worth of paint on the wall.
Unless you are using Aura, or a comparable high end paint, I would go with the gray primer.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
ToolSeeker (10-16-2013)
Old 10-16-2013, 08:30 PM   #4
ltd
Rewards Points: 536
depends on what red/burgundy you choose .I always use Sherwin Williams paint .Sherwin Williams will tell you if your color needs a gray primer, and what shade of gray .i cant speak to other paint brands but if s/w says you need a primer ,well then you need a primer
ltd is offline   Reply With Quote
Old 10-16-2013, 10:37 PM   #5
Rewards Points: 4,796
What the last 2 guys said...
Deep reds almost always apply truer with a gray primer underneath. However it's best if you know the correct shade recommended for the particular color from the manufacturer. But if you want to just go for it, then just paint until it looks good to you, and then you won't need the primer.
jeffnc is offline   Reply With Quote
Old 10-17-2013, 02:22 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 300
for panda2's info
which could mean 4 or 5 times instead of 1 primer and 2 finish coats
Old 10-17-2013, 03:15 AM   #7
Originally Posted by chrisn View Post
for panda2's info
Possibly, but probably not. It could also be 2 coats of finish paint, instead of 1 primer and 2 finish. Or it could be 3 or 4 coats of finish paint. You pays your money and you takes your chances. There is no way to tell ahead of time how many coats it will take, and we can't sit here and tell him what level of color saturation he's happy with, so this is all guesswork.
Old 10-17-2013, 03:34 AM   #8
747
registered
747's Avatar
Rewards Points: 534
Prime then sherwin williams interior superpaint. Pic a sheen. Flat,satin,semigloss.
747 is offline   Reply With Quote
The Following User Says Thank You to 747 For This Useful Post:
Gymschu (10-17-2013)
Old 10-17-2013, 10:22 AM   #9
Rewards Points: 77
I can't believe I know the answer to this! I've done red inside, and right this very minute we're doing a red trim outside, which is looking really nice.
Use a primer coat in a flat, medium grey. Use a warm or cool grey depending on whether your red is warm or cool. Whether you choose a special primer or this is just a coat of grey-colored paint depends on what you're painting over.
After that, two coats of dark red in your favorite sheen will be enough, AND the red color will look its best.
Are you doing ALL the walls dark red? Are most of the walls covered with cabinets and decorations, or will there be a lot of red showing? If there will be a lot of wall showing, you might not want ALL the walls to be totally red. Bright yellow and tan are two colors that work great with dark reds. The bright yellow and dark red is really cheery and warm; the tan and dark red is more of a classic, sophisticated look.
P.S. In case you were wondering, I use AFM Safecoat paint. We've also done one bright yellow room in Sherwin Williams Harmony.
Angelique is offline   Reply With Quote
Old 10-17-2013, 10:46 AM   #10
Rewards Points: 984
The first coat needs to be whatever will adhere to kitchen residue.
If you go with the dark color your next shopping trip may be to purchase more lighting and possibly a few hundred watts more but each has their own ideas about that.
Old 10-17-2013, 11:17 AM   #11
That really quite depends on the shade of red and the particular paint.
Old 10-17-2013, 11:18 AM   #12
Presumably the walls will be cleaned if there's any "residue". This is preferred over priming.
Old 10-17-2013, 11:40 AM   #13
Rewards Points: 984
This is a pre-owned home and there will be residue without a doubt, even with the best of vent hoods, unless there was a kitchen / cooking phobia and all meals were take out.
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
