Do I Need To Prime Textured Ceiling? - Painting - DIY Chatroom Home Improvement Forum
Old 09-19-2013, 10:17 PM   #1
Rewards Points: 83
Do I need to Prime Textured Ceiling?
Just had the drywall guys finish my drywall in basement and they put a knockdown texture on the ceiling. Usually they said you don't even need to paint it but unfortunately I used the purple mold and mildew resistant drywall on everything so in some small spots you can see the purple showing through.
Do I need to prime or can I just use a coat of ceiling paint? Or can I just use a primer and leave it in just primer without top coating it? Trying to avoid doing a primer/basecoat on the ceiling if I can. As of right now it already looks awesome and is pretty white its just a few spots were the purple shows through. Let me know! Thanks!
Nick
AllGoNoShow is offline   Reply With Quote
Old 09-20-2013, 01:11 AM   #2
cdaniels's Avatar
You should have primed it before the texture.Don't prime it and leave it.If you're only going to do one coat use a quality ceiling paint.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 09-20-2013, 07:32 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
Yeah, what he said.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-20-2013, 08:17 AM   #4
Gymschu's Avatar
Rewards Points: 490
If you lay it on nice and keep moving so you don't get any lap marks, ONE coat is sufficient. A quality ceiling paint like SW's Emminence will leave you with a nice, white, flat finish. By keeping a wet edge, the ceiling paint soaks up into the texture just enough to give you a nice finished look.......without having to prime or apply 2 coats.
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (09-20-2013)
Repairing textured ceiling? spinnaker Drywall & Plaster 10 08-03-2013 02:11 PM
Textured ceiling paint cracked and peeling bigbearbear Painting 3 09-21-2012 03:01 AM
What tool to use for applying textured ceiling? Jrosssijr Drywall & Plaster 5 06-08-2012 03:57 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Can drywallers cut into existing textured ceiling? wease Remodeling 2 12-23-2006 01:40 PM
