Do I Need To Clean The Walls Before Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 02:13 PM   #1
EkS
Do I need to clean the walls before painting?
Just bought a house and the walls have dust that has never been cleaned. Do I have to clean the walls before painting? I've tried soap and water, and it's tough.
Would Kilz paint cover this? If it does, do I have to worry about adhesion?
What about sanding?
Any tips?
EkS is offline   Reply With Quote
Old 06-15-2010, 02:27 PM   #2
Yes, surfaces need to be clean before coating.
Get a box of TSP and mix it according to the directions. Wash and then rinse. Wait until dry and then paint.
hennyh is offline   Reply With Quote
Old 06-15-2010, 02:43 PM   #3
EkS
I've been told to try and stay away from chemicals. I haven't heard of TSP. Would it hurt the walls? Where can I get it and will it remove dirt easier than soap and water?
Old 06-15-2010, 03:09 PM   #4
TSP has been the standard product for cleaning walls prior to painting for decades. It's sold everywhere. (paint, hardware, homecenter stores).
It's Tri Sodium Phosphate which is a powerful soap.
If you don't want to use it and your walls aren't that dirty I'm sure most any wall cleaner would be better then nothing. (maybe even plain old hot water).
Old 06-15-2010, 03:45 PM   #5
EkS
Well I've tried just soap and water, like I stated above, and it's tough but it's working. A lot of elbow grease is needed though. I only have 3 weeks to finish this and a lot of other things. So I just need a fast and easy way of doing this.
I've been recommended Kilz. To just do a quick clean with soap and water and paint with Kilz. No hard scrubbing needed, but looking for other opinion/options. I only want to do this once!
Old 06-15-2010, 05:31 PM   #6
EkS
Well looking around they sell two types of TSP. One with phosphorus and one without. Looks like the one without phosphorus is less powerful, but safer to use indoors.
Anyone try TSP with/without phosphorus for indoor use?
Old 06-15-2010, 06:32 PM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Either will be OK. Just about any bonding type primer would be better than Kilz. Go to a real paint store and ask what they would recommend, do not rely on ANY information given to you @ Lowe's or Home Depot. Most likely the "experts" there do not have a clue as to what you are talking about.
Old 06-15-2010, 11:17 PM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
If soap or TSP is not working so well, get a pole sander. You really want to do everything you can to get as much of the dirt off as you can.
Old 06-16-2010, 12:55 AM   #9
EkS
Well I'm using the TSP without phosphorus. It's a step above soap and water, so I'll be using that to wipe down some but won't be using much elbow grease. Then I'll be using a pole sander with 220 grit sander paper. Then I'll be using primer. I hope this will do the trick, and I won't have to do this again!
I think the previous owner was a smoker because the ceilings are dirty.
Old 06-16-2010, 03:46 AM   #10
chrisn's Avatar
Rewards Points: 228
Then you should really use either Zinsser Bin or their orderless oil based primer.
Old 06-16-2010, 11:06 AM   #11
EkS
Is that the same as the Kilz?
Old 06-16-2010, 07:00 PM   #12
chrisn's Avatar
Rewards Points: 228
NO, it is better than Kilz, unless you get the original kilz oil
Old 06-17-2010, 12:58 PM   #13
Rewards Points: 526
I would use 100 grit paper, 120 at the most.
Windows is offline   Reply With Quote
Old 06-17-2010, 01:42 PM   #14
EkS
Is 220 grit too fine? I actually have 100 & 220 but I was told 220 before primer is good.
Old 06-17-2010, 11:02 PM   #15
Rewards Points: 526
I would use 220 on new drywall with a skim coat. If you are trying to grind down crud that is embedded in the coating, 100 or 120 will be more effective.
Painting Garage Walls PearlWhiteGT Painting 10 08-18-2009 09:38 AM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 05:21 PM
Painting Stripes on Fresh Painted Walls kimmyb Painting 1 02-21-2009 03:48 PM
Painting Vinyl Coated walls WiccanOne Painting 8 02-17-2009 10:28 PM
painting 18' walls sedona48 Painting 1 02-07-2004 07:18 PM
