Do I HAVE Add More Compound - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 06:45 PM   #16
Here we go again.
The Following User Says Thank You to jsheridan For This Useful Post:
djlandkpl (04-23-2013)
Old 04-23-2013, 07:09 PM   #17
Here we go again with useless, sarcastic posts. At least add some actual non-sarcastic content along with the sarcasm to make the posts slightly worth while.
Dorado is offline   Reply With Quote
Old 04-23-2013, 08:39 PM   #18
I, We have been adding "actual non-sarcastic content". You're either not processing it, ignoring it, or just not choosing to accept it. What else is there to say on the topic. Some more actual non-sarcastic content, it's standard fare after priming new drywall to walk the walls and knife high and low spots. Final drywall finishing is rarely perfect and the primer lights up the required touch ups, it's expected. Maybe it's another regional thing, but I've never seen guys standing around discussing high build primers or level 5 to solve the defects. It takes a few minutes to spackle the defects. If you want to try your hand sanding out primed high spots that's your option, but I'm telling you it's difficult, it cuts the primed surface and leaves a gouge that requires spackling, maybe twice. So we're back to spackling, which is where we were to start. But if you want to build it up with multiple layers of primer, go for it and tell us how it works out for you. What about the low spots?
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
chrisn (04-24-2013), princelake (04-23-2013)
Old 04-24-2013, 03:43 AM   #19
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
[QUOTE=Dorado;1165782]"KILZ HIGH BUILDŽ is a unique, interior water-based primer that can be applied more thickly than most primers. It creates a finish equivalent to a fully prepared skim coat (Level 5 finish) when sprayed. Spray, brush or roll." So I guess nobody here thinks multiple coats of regular primer would accomplish the same. I think it would work for sure with enough coats but I'd at least try sanding after the coat that was already applied.[/QUOTE]
baloney. I guess you have done this and actually seen the results? I thought not.
chrisn is online now   Reply With Quote
Old 04-24-2013, 05:48 AM   #20
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 426
Let's simply do the math so I won't sound "sarcastic".
Multiple coats of primer will take multiple days to apply so the primer is dry enough for sanding and not rolling into little gribnits when sanding.
Lets say even 2 days.
The OP needs such a fine skim, it will be ready to sand in a few hours and ready for primer. 1 day.
I understand you're trying to help and bring up ideas but not all ideas work.
I'd rather finish in half the time. How about you?
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 04-24-2013, 10:00 AM   #21
Rewards Points: 101
The answer to your question: "Do I have to add more compound" is YES.
JMDPainting is offline   Reply With Quote
Old 04-24-2013, 11:10 AM   #22
I'd just spend 30 seconds sanding the existing coat to see if it works. I wouldn't try more primer after that unless maybe I didn't have joint compound or it looked very close to smooth.
Old 04-24-2013, 07:53 PM   #23
Rewards Points: 5,974
And I don't care who said it, where they said it, or who they said it to, YOU CANNOT GET A L5 WITH PAINT. And yes I have used high build primers. No they will not work for this. I don't get it all the time and money to get this far and have a decent job and now for a 15 minute fix you want to half a$$ it.
Old 04-25-2013, 04:58 AM   #24
chrisn's Avatar
Rewards Points: 128
exactly
Old 04-25-2013, 06:03 AM   #25
Rewards Points: 874
Thanks everyone. I applied a skim coat and sanded last night. Will prime that wall tonight. Lets hope it comes out withour the line
Mstrlucky74 is offline   Reply With Quote
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 10:33 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 11:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
