Do I HAVE Add More Compound - Painting - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 04:51 PM   #1
Rewards Points: 878
Do I HAVE add more compound
Primed newly Sheetrock walls. There are one or two areas where u can see it wasn't sanded enough prior to priming(you can see the edges of compound). Is there anyway it can just be sanded down and primed again or does a skim coat have to be applied? Thanks a lot.
Mstrlucky74 is offline   Reply With Quote
Old 04-22-2013, 05:07 PM   #2
Rewards Points: 512
skim, sand, prime.
princelake is offline   Reply With Quote
The Following 3 Users Say Thank You to princelake For This Useful Post:
ltd (04-22-2013), oh'mike (04-22-2013), zakany (04-24-2013)
Old 04-22-2013, 05:43 PM   #3
Follow prince, there's no sanding joint compound after primer.
Old 04-22-2013, 05:58 PM   #4
Rewards Points: 878
It is so light and hardly noticeable... Will another coat of prime then 2 coats of paint cover it
Old 04-22-2013, 07:26 PM   #5
Rewards Points: 512
i havent seen it but most of the time it will be seen. a matte paint without direct sunlight/direct lighting hides all kinds of imperfections. but your probably going to have to skim sand and paint it or live with the minor imperfection
Old 04-22-2013, 07:36 PM   #6
Between coat touch spackle work is where I use lightweight vinyl spackle. Shrinks very little and dries fast.
Old 04-22-2013, 07:37 PM   #7
DIY staff
Rewards Points: 7,174
That sort of mudding is fast and simple---just do it---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Sir MixAlot (04-22-2013), ToolSeeker (04-24-2013)
Old 04-22-2013, 08:50 PM   #8
I'm probably the least experienced one here, but I'd still try sanding a piece of it and see what happens.
Dorado is offline   Reply With Quote
The Following User Says Thank You to Dorado For This Useful Post:
Gymschu (04-23-2013)
Old 04-23-2013, 02:48 AM   #9
Trust issues? Doubtful? Cynical?
How do you think we've arrived at our particular advice Dorado? The very experience you claim you lack.
I already know what happens.
All sanding does at this point is create a bigger problem that requires spackle, why waste your time and create a larger fix?.
The Following 3 Users Say Thank You to jsheridan For This Useful Post:
chrisn (04-23-2013), ltd (04-23-2013), Mr. Paint (04-23-2013)
Old 04-23-2013, 04:53 AM   #10
Rewards Points: 878
The guy who did the tape and compound said i can try to add another coat of primer to the area and that might cover it.
Old 04-23-2013, 05:55 AM   #11
And that guy does what for a living?
Old 04-23-2013, 09:17 AM   #12
If there's a bump that's no higher than the thickness of the primer then as long as the primer is sandable it seems it can be sanded out. If it doesn't work on a small test area then clean up with a sponge and skim coat it and you only wasted about a minute.
There's another thread where people are saying that paint can hide some slight imperfections, so another coat of primer may work too.
Old 04-23-2013, 04:48 PM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 606
there you go, most likely these "people" are true experts
Old 04-23-2013, 05:20 PM   #14
DIY staff
Paint needs a smooth surface---some drywall touch ups are per for the course with new work---
Fill and sand--then prime the touch up----it's not a big chore----
I gave up on drywalling if the customer wishes to paint----now the price includes priming and touch ups----
To many homeowners do not do proper preparation for painting----which includes minor patching.
Old 04-23-2013, 05:32 PM   #15
"KILZ HIGH BUILDŽ is a unique, interior water-based primer that can be applied more thickly than most primers. It creates a finish equivalent to a fully prepared skim coat (Level 5 finish) when sprayed. Spray, brush or roll." So I guess nobody here thinks multiple coats of regular primer would accomplish the same. I think it would work for sure with enough coats but I'd at least try sanding after the coat that was already applied.
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 03:59 AM
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 09:33 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
