-   -   Do I HAVE add more compound (http://www.diychatroom.com/f4/do-i-have-add-more-compound-177851/)
Mstrlucky74 04-22-2013 04:51 PM
265 Attachment(s)
Primed newly Sheetrock walls. There are one or two areas where u can see it wasn't sanded enough prior to priming(you can see the edges of compound). Is there anyway it can just be sanded down and primed again or does a skim coat have to be applied? Thanks a lot.
princelake 04-22-2013 05:07 PM
skim, sand, prime.
jsheridan 04-22-2013 05:43 PM
Follow prince, there's no sanding joint compound after primer.
Mstrlucky74 04-22-2013 05:58 PM
265 Attachment(s)
It is so light and hardly noticeable... Will another coat of prime then 2 coats of paint cover it
princelake 04-22-2013 07:26 PM
i havent seen it but most of the time it will be seen. a matte paint without direct sunlight/direct lighting hides all kinds of imperfections. but your probably going to have to skim sand and paint it or live with the minor imperfection
jsheridan 04-22-2013 07:36 PM
Between coat touch spackle work is where I use lightweight vinyl spackle. Shrinks very little and dries fast.
oh'mike 04-22-2013 07:37 PM
That sort of mudding is fast and simple---just do it---
Dorado 04-22-2013 08:50 PM
I'm probably the least experienced one here, but I'd still try sanding a piece of it and see what happens.
jsheridan 04-23-2013 02:48 AM
Trust issues? Doubtful? Cynical?
How do you think we've arrived at our particular advice Dorado? The very experience you claim you lack.
I already know what happens.
All sanding does at this point is create a bigger problem that requires spackle, why waste your time and create a larger fix?.
Mstrlucky74 04-23-2013 04:53 AM
265 Attachment(s)
The guy who did the tape and compound said i can try to add another coat of primer to the area and that might cover it.
jsheridan 04-23-2013 05:55 AM
And that guy does what for a living?
Dorado 04-23-2013 09:17 AM
If there's a bump that's no higher than the thickness of the primer then as long as the primer is sandable it seems it can be sanded out. If it doesn't work on a small test area then clean up with a sponge and skim coat it and you only wasted about a minute.
There's another thread where people are saying that paint can hide some slight imperfections, so another coat of primer may work too.
chrisn 04-23-2013 04:48 PM
there you go, most likely these "people" are true experts:laughing:
oh'mike 04-23-2013 05:20 PM
Paint needs a smooth surface---some drywall touch ups are per for the course with new work---
Fill and sand--then prime the touch up----it's not a big chore----
I gave up on drywalling if the customer wishes to paint----now the price includes priming and touch ups----
To many homeowners do not do proper preparation for painting----which includes minor patching.
Dorado 04-23-2013 05:32 PM
"KILZ HIGH BUILDŽ is a unique, interior water-based primer that can be applied more thickly than most primers. It creates a finish equivalent to a fully prepared skim coat (Level 5 finish) when sprayed. Spray, brush or roll." So I guess nobody here thinks multiple coats of regular primer would accomplish the same. I think it would work for sure with enough coats but I'd at least try sanding after the coat that was already applied.
