DIY Exterior Of House Paint Job: Need Advice - Painting - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 10:09 PM   #1
DIY Exterior of House Paint Job: Need Advice
Hello Everyone!
Well, I almost purchased Behr Paint today, but something compelled me to do a little research, and I came across these forums. I'm glad that I did! I used Behr for all of my interior paint, and it was really hit or miss.
I live in Central Florida, lots of sun, rain, humidity.
I am painting the exterior of my stucco/wood house. It hasn't been painted since it was built 13 years ago, and it shows. The base of the house is stucco, and the top is wood. I just pressure washed my house today.
I've seen lots of recommendations for Sherwin Williams (Duration) and Benjamin Moore (Aura) paints. However these are just too expensive for me. I was hoping to keep the paint @ $30-$40 per gallon. I've also seen recommendations for SuperPaint, which would fall within this range.
What about Benjamin Moore's lineup: Particularly Moorgard, and Moorlife?
These are in the $30 range, but I haven't heard a lot about them. Are they considered a good Benjamin Moore paint and somewhat equal to Sherwin Williams SuperPaint? If not, what are some recommendations for $30-40 per gallon paint?
Also, do I need to prime the stucco? what kind of primer should I use? Should I stick with the same brand for primer as paint for tinting purposes?
Thank you in advance!
jamesp880 is offline   Reply With Quote
Old 01-31-2009, 11:24 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
probably either one of those paints will be good as long as the old paint is intact, i would guess you dont have to prime but if you have bare areas it might not be a bad idea ,should have this info on the can label good luck
Tom Struble is offline   Reply With Quote
Old 02-01-2009, 06:26 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Do you have a Duron store near you? Their Weather Shield is good.
Old 02-01-2009, 08:41 AM   #4
I guess you need to decide what quality of paint you want and how you want your house to look in ten years. The more you pay, the better the quality of paint you get. Price and quality in regard to paint go hand in hand. Ben Moore and Sherwin are excellent brands. I would never purchase a True Value brand or pay $25 for an exterior paint and think I was buying a good exterior paint. Anything under $30 isn't a quality paint.
Josh Jaros
jaros bros. is offline   Reply With Quote
Old 02-01-2009, 09:41 AM   #5
Josh Jaros
I'm definitely going to go with SW or BM, I'm just having a hard time determining which particular paint to go with. The top of the line paints from SW (Duration) and BM (Aura) are too expensive, so I was inquiring about other paints in their respective portfolios. What would be the next step down that would represent a good paint at a more reasonable price?
Thanks!
Old 02-01-2009, 03:14 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
BM/SW make some great paints but....
Your location leads me to another suggestion
I'd strongly recommend a regional brand local to you called Flex-Bon made specifically for your application and climate
Their products work very well in your type of climate (semi-tropical) and your type of housing
(stucco/wood mix)
Though the BM/SW companies have excellent products, they are meant to be used all across North America, and are formulated as such
(nothing wrong with that but...)
Flex-Bon has no desire to become a national brand so to speak
They are local to Florida and make their coatings specifically for Florida's conditions
Although I'd never use them up here in New England (not quite semi-tropical up here), they are definitely my first choice when painting exteriors in Florida
slickshift is offline   Reply With Quote
Old 02-01-2009, 11:56 PM   #7
(stucco/wood mix)
Thanks for the tip slickshift. I definitely experience a tropical environment. I checked into the company...Unfortunately there are not any dealers within a couple hours of me. Do you have any other recommendations other than Aura and Duration? Is the Moorgard, gloss line good for what I need?
BEHR Paint Problem Please advise PaintPro Painting 14 05-13-2012 12:15 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
What's the best way to paint the entire interior of our house? Shpigford Painting 21 07-17-2011 06:51 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
Paint or stain for shingled house? skwpt Painting 6 09-19-2007 07:41 AM
