Dinning Room Table - Painting - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 07:56 AM   #1
dinning room table
painted a dinning room table teal color what type of coating should i use so that i can clean it
mshelledy is offline   Reply With Quote
Old 07-24-2012, 08:15 AM   #2
Dinning room table
painted a dinning room table teal color want to put a coat of clear on it what do i use?
Old 07-24-2012, 03:00 PM   #3
Rewards Points: 4,796
Oil based polyurethane is recommended. If you don't like the smell or can't wait for it to fully dry or don't like trying to clean oil with solvents or don't want to throw away your brushes, then use a water based one like Polycrylic. It dries so fast that it's difficult to smooth out correctly. Also, I've had some staining issues on my dining room table. I've never really had a problem with oil based polys, so I'm going back to that next time.
jeffnc is offline   Reply With Quote
Old 07-24-2012, 06:01 PM   #4
Too Short? Cut it Again!
Careful. You do not want to use an oil based product over an acrylic. It will not adhere. You might get things to work the other way around.
Remember that acrylics take 30 days to cure completely so avoid putting anything heavy on it. If you put on two coats, you should not need a clear coat. I use semi-gloss on gallery pedestals all the time and the owners wipe them down on a regular basis. You will probably be putting placemats on the table anyhow?
Old 07-24-2012, 06:11 PM   #5
Oil over latex is fine. Glossy finish should be sanded first.
Straight glossy latex is a bad idea for a dining room table - things you put on it will tend to stick. You want an oil based or water based polyurethane. Or an oil based glossy paint to begin with would work as well. Polyurethane would be easier to maintain in the future IMO.
Old 07-25-2012, 05:31 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
I would avoid all that and just use a straight 100% semi gloss latex, done, no need for anything else.
chrisn is online now   Reply With Quote
Old 07-25-2012, 08:14 AM   #7
Seriously? Semigloss latex on a dining room table? I don't know anyone who recommends this guys. It's also not recommended for bookshelves, etc. It's famous for having things sitting on it and sticking to it. It's not as hard a surface as polyurethane. Anything like heavy water glasses or serving bowls will tend to make indentations in it. I'm really confused why you guys are recommending this.
Old 07-25-2012, 08:49 AM   #8
Sorry. Not up for an argument with you.
Old 07-25-2012, 10:38 AM   #9
I'm glad for that, so we won't hear any more about not being able to put oil over latex, having to use placemats, etc.
In addition, latex does not lay out as well as oil, or even the thin polycrylic. Yes you can add Floetrol, but you'll still often get some brushmarks. None with oil polyurethane. You could spray it on, but you'd still have the sticking and denting problem with the relatively soft acrylic.
Old 07-25-2012, 02:39 PM   #10
Rewards Points: 394
I agree that a regular wall and trim SG latex (even 100% acrylic) should not be used for this, as it will have blocking issues. If latex was applied already, a water based clear poly should help with blocking and cleaning. Otherwise an alkyd or even an acrylic porch and floor paint would provide better perfomance (abrasion resistance, blocking).
Will22 is offline   Reply With Quote
Old 07-25-2012, 04:26 PM   #11
chrisn's Avatar
Rewards Points: 496
I never recommended it, He already put it on
Old 07-25-2012, 09:02 PM   #12
What makes you say that? The OP only mentioned the color used.
Old 07-26-2012, 12:14 AM   #13
Mentioned it Twice actually
And I see that the din making has begun!
Evstarr is offline   Reply With Quote
Old 07-26-2012, 04:07 AM   #14
chrisn's Avatar
Rewards Points: 496
quote from post 1 AND 2
"painted a dinning room table teal color"
read first then tou can make you're supposid helpful comments
garage room bmorekid Building & Construction 4 01-02-2012 12:22 AM
Interior Decorating with Paint Advice- Newbie, Please help KyahsMum Painting 6 11-27-2011 01:55 PM
removing roof supports in attic, installing a room denemante Building & Construction 4 01-24-2011 08:51 PM
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 05:50 PM
dining room table TBS Painting 2 11-06-2008 12:48 PM
