Dimply Matt Paint??? - Painting - DIY Chatroom Home Improvement Forum
Old 04-24-2014, 12:14 PM   #1
Rewards Points: 16
Dimply matt paint???
Can some one please help. I am new to this forum and desperately need help. I have had my hall walls replastered. They were left to dry sanded down and two coats of thin mist coat applied. I tried to paint them with paint brush but had flashing. Walls rubbed down again and now i have tried to use a roller!! I am now having a textured finish which is dimply stipply kind of thing - i am sure you will know what i am talking about!! Is my paint to thin/thick? I am using Dulux Endurance. I have used the Hamilton Vantage smooth and textured roller which i was told was good! Please help someone.
westiekath is offline   Reply With Quote
Old 04-24-2014, 12:54 PM   #2
Rewards Points: 16
Anyone help?
Old 04-24-2014, 04:29 PM   #3
Gymschu's Avatar
Rewards Points: 838
Plaster walls usually require at least 30 days to fully dry and cure. That could be the reason for the flashing.
I'm not familiar with Hamilton Vantage rollers.
A pic would help us help you better.
Old 04-24-2014, 04:34 PM   #4
Rewards Points: 13,732
No clue what thin mist coat is.
Should have been rolled with a primer before painting with two coats of paint.
Old 04-25-2014, 06:11 AM   #5
Rewards Points: 16
Hi joecaption and thanks for reply. The plasterer told me to put on 2 thin watered down coats of emulsion to seal the walls - i thought this was normal?
Old 04-25-2014, 06:24 AM   #6
Rewards Points: 5,974
Almost any roller will give a stippled effect. The only way to get a really smooth finish would be to spray. The problem with that is if you ever need to touch up the paint it would also have to be sprayed or the repair would look horrible. I also have never heard of that brand roller cover. Might try a short nap like 3/8" micro fiber roller. There will still be some stipple but not much.
The Following User Says Thank You to ToolSeeker For This Useful Post:
westiekath (04-25-2014)
Old 04-25-2014, 06:26 AM   #7
Rewards Points: 16
ha ha spraying is out of the question - that must be how professionals get their walls looking good then Oh well looks like I am going to have to suffer it then - not happy about it but what can I do!! Thanks again
Old 04-25-2014, 07:14 AM   #8
Most pro's that spray also go back and do what is called back roll. That is take an almost dry roller and roll the walls after they are sprayed. What this does is give it the stipple effect so they can be touched up later.
Old 04-26-2014, 12:06 PM   #9
Rewards Points: 16
Quite the opposite of what I want. I am just going to give the walls another coat and then what will be will be
Thanks for taking time to reply.
Old 04-26-2014, 12:30 PM   #10
Rewards Points: 2,638
That rather sounds like the nap of the roller was too long.
SPS-1 is offline   Reply With Quote
Old 04-26-2014, 01:55 PM   #11
Gymschu's Avatar
Rewards Points: 838
You could really go a looooonnnnnnggggg ways toward getting better help from DIYchatroom with PICTURES. A pic is indeed worth a thousand words. We are all just taking a stab in the dark on how to approach your situation without pics to give us some idea.
P.S. Were the walls plastered or skim-coated with joint compound? There's a huge difference in how you approach dealing with these very different substrates.
Old 04-26-2014, 03:06 PM   #12
Rewards Points: 16
I tried to take pic but it really wasn't showing up the problem but it looks like the skin of an orange. Going by what other threads are saying I think it is j u st what I can expect when using a roller. The walls were just skimmed with the pink plaster stuff is it gypsum can't remember the name of it. .My husband is saying I am fussing too much and it looks fine - just me wanting my walls to look good
The Following User Says Thank You to westiekath For This Useful Post:
Gymschu (04-26-2014)
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
