#1 |
Diminishing Texture on Walls
We recently bought a house built in 1956 & all of the vertical walls have a swirl textured pattern & we don’t want to hire someone to skim the walls, but would like just to diminish the swirls. It has been suggested to me to thin joint compound with water to the consistency of paint and then “paint” the walls with this mixture. Let dry & then paint with the desired color.
If anyone had any experience with this or other method to diminish the texture on walls, I would appreciate learning of your experience. Thanks. |
#2 |
Rubbin walls since'79
Sorry to say- skimming is the way to go. Just because you don't want to do it doesn't mean it isn't the right way.
If you roll mud on , you will get a weird tipped roller stipple- it will not lay flat. Do a test on a piece of primed sheetrock- no need to believe me.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
| The Following User Says Thank You to Brushjockey For This Useful Post: | Gymschu (12-31-2011) |
#3 |
What a mess that would make with it thined that thin.
Shim coat, go over it with 1/4" sheetrock, or leave it. |
#4 | |
paper hanger and painter
Diminishing Texture on WallsQuote:
sKim
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Do a search, there's literally dozens of threads on DIYchatroom about this very topic. You can roll the thinned down joint compound onto the wall, BUT, you will have to skim it with a broad knife to smooth it down. You will have some ridges but don't worry too much about those. When dry, you can scrape or sand the ridges smooth. More than likely you will have to apply TWO coats of mud to properly hide the old swirls. I won't lie.......this is one heckuva a messy job.
#6 |
DEFINITELY agree with Skimming!!!
>>> BUT...Vacuum & wash the walls first!!!! * Use your bristle-brush attachment on your Shop-Vac. * Lotsa dust/dirt can be lodged in all those swirl-valleys! * When dust is removed, wash the walls with a weak POWDERED Dirtex solution. For THIS kind of texture, LIGHTLY scrub with a soft-bristled scrub-brush. * Let dry a day. >>> NOW....prime all your walls that you wish to "smooth". * Skim-coat will hold nicely to primer, and you'll now have the ideal substrate for it.....meaning CLEAN & PRIMED. * I'd HIRE the skimming done!! It takes a practiced hand to really make a wall look nice...WITHOUT APPLYING EXCESS MUD .* Another important point: Final sanding is minimized if you don't have to sand back a heavy-handed mud layer!!! * When final-sanding is done, vacuum-off ALL dust. Use a FINE-DUST filter-bag for this!! * Lightly sponge-rinse any remaining dust. Change water often. >>> Do a final priming when wall is dry. A skimmed wall is waaaayyy to thirsty to just paint over!! MY first choice for primer here is Zinsser 123. Much better hold-out than a cheap PVA/Drywall-class primer! ACE's "Enamel-Undercoater" is another good choice. >>> I've always said...a well done wall-skim-job can add $$$value to a home, & is always worth the investment! >>> Picture 2 identical homes....one with horrid old texture. The other with nicely-done skimmed walls. GUESS which one will PROBABLY sell faster ![]() Faron |
| Display Modes | |
| Help with texture - any opinions on SW Faux Impressions products | Sangiovese | Painting | 0 | 10-08-2011 09:10 AM |
| Can you texture plaster walls? | destes50 | Painting | 5 | 11-06-2009 10:51 AM |
| Paint options for basement walls and floors | 68tele | Painting | 8 | 10-28-2009 07:09 PM |
| Smoothing out skip troweled wall texture | wem | Remodeling | 2 | 03-03-2008 12:57 PM |
| Keeping Water out of the Top of Brick Walls | o2barockstar | Roofing/Siding | 4 | 02-18-2008 03:50 PM |
