Devflex Waterborne Acrylic - Painting - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 10:17 AM   #1
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Just curious if anyone has used this product before on a regular basis. I'm working in a high end residential and all the basement trim is done in this. Originally, the client thought the trim was clear coated after being applied, which sounded odd. Actually, it was sprayed with this product.
If you have used this or a similar waterborne product interested to hear your opinions as far as application, etc..
thanks,
Kevin
Kevin M. is offline   Reply With Quote
Old 01-08-2010, 04:20 PM   #2
NAV
I use a couple hundred gallons or more of Devflex each year.
its a great industrial coating. I would not use it on residential applications but have used it on wood at restaurants with great results.
what do you want to know about it?
it sprays great - flashes in hot weather if you are a bad spray man
it brushes and rolls great
it performs good.
has decent gloss and color retention.
NAV is offline   Reply With Quote
Old 01-08-2010, 07:46 PM   #3
Kevin M.'s Avatar
Rewards Points: 150
it performs good.
Hey Nav,
Thanks for the info. Any particular reason you would not use it in a residential application?
thanks,
Kevin
Old 01-11-2010, 07:24 AM   #4
NAV
there are better products out there for residential paint that cost less per gallon.
Scratch in Acrylic Bathtub shadfly Kitchen & Bath Remodeling 5 07-24-2009 05:08 PM
Oil-based paint vs. 100% Acrylic paint: which one more durable? ohman Painting 11 07-03-2009 01:46 PM
Decorative acrylic cabinet door panels..... SandyK General DIY Discussions 1 02-20-2009 04:00 PM
Acrylic tub surrounds vs others? Petermgr Plumbing 1 11-08-2008 01:10 PM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
