Determining Number Of Paint Layers - Painting - DIY Chatroom Home Improvement Forum
Old 03-10-2015, 08:27 PM   #1
Rewards Points: 14
Determining number of paint layers
Is there anyway to find out how many layers of paint are on wood thats already been painted? A friend of mine and I are contractors. He claims he has been putting 2 coats of exterior paint on wood projects we make, but I swear he is only putting on one. How can I tell for certain?
draft34 is offline   Reply With Quote
Old 03-10-2015, 08:41 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
A Tooke gauge could tell you for sure. One thing to keep in mind is that the word "coat" is somewhat subjective in residential painting. One painters "coat" may be twice as thick as another's.
Another way to get a sense of what kind of coating thickness your getting on future projects would be to track how much material is used and compare that to the square footage. Lot of variables in that calculation of course, texture of surface, method of application, etc.. But you should be able to get in the ballpark enough to determine if your getting one or two coats.
Jmayspaint is offline   Reply With Quote
Old 03-10-2015, 08:53 PM   #3
Rewards Points: 14
We start with bare plywood. My friend feels if we use paint + primer paint that 1 coat is sufficient because the paint claims to be a 1 coat paint. According to the manufacturer that is wrong. The first coat is the primer coat, the 2nd is the paint coat. According to Behr and Valspar on bare wood you can either use a primer then 2 coats of paint or 2 coats of paint+primer paint.........but never only 1 coat of paint + primer paint. I can tell my friend this until I am blue in the face and he wont listen. He feels because its a paint+primer paint, and in his opinion its goes on thick enough in 1 coat that that will be sufficient. That 2 coats is overkill. Personally I dont think it will hold up in weather.
Old 03-10-2015, 09:09 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
No, it likely won't. Another gross misuse of the phrase paint&primer.
Old 03-10-2015, 09:14 PM   #5
Rewards Points: 13,458
Your right draft and he's dead wrong.
Primer and paint may be fine for a precisely surface, not for bare wood.
This one's going to come back and bite someone on the butt.
Sure way to not get repeat customers.
Old 03-11-2015, 08:05 AM   #6
Rewards Points: 1,382
Ask your friend if he is going to fix it when it fails. It will. And none of the Paint and primers claim to be one coat on anything but a previously painted, sound surface. And even then they say a second coat may be desired for best appearance. (a slight change from the old "second coat is required for best appearance", which is how they weasel out of warrantee claims against the P&P labelling.) The marketing is a downright lie. Some have started to claim that they seal common stains, but they never mention that it may take up to 6 coats to seal said stains. Try sealing coffee or stamp pad ink with one of them. And if you have children under the age of 5 you are well aware that stamp pad ink is a "common household stain".
klaatu is offline   Reply With Quote
A Home Depot/Behr paint experience jeffnc Painting 31 05-25-2013 11:14 AM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Achieving smooth finish on old woodwork with multiple layers of paint designSTL Painting 5 08-23-2012 05:49 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
