Deglosser For Crown Molding - Painting - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 08:27 PM   #1
Deglosser for Crown Molding
I understand that the best way to degloss is to sand. But doing that on complex crown molding with 40 year old oil-based semi-gloss is a problem in oh so many ways.
Someone please give me some advice! Product specifics would be VERY helpful. I don't mind buying extra carbon filters for my air cleaners, or wearing a respirator. But sanding this stuff is just not realistic.
Thanks!
Maureen23669 is offline   Reply With Quote
Old 02-21-2013, 08:37 PM   #2
Rewards Points: 13,300
They make a chemical deglosser.
Old 02-21-2013, 11:25 PM   #3
Gymschu's Avatar
Rewards Points: 486
Steel wool or a sanding sponge would do the trick. Of course with steel wool you will want to remove any remnants of it on the crown moulding as it would react with latex paint and leave rust spots. A sanding sponge is easy to work with and would get into nooks and crannies because of its' flexibility. Liquid deglossers are ok, not ideal, but they are generally effective. Just pour some on a rag and rub it over the surface.
Old 02-22-2013, 04:20 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
Just prime it first(after cleaning) with Zinnsers 123 , Fresh Start or any quality BONDING primer. The crown is not going to take any abuse and this will work just fine.
PS, forget the degosser, they don't work well
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (02-22-2013)
Old 02-22-2013, 04:21 AM   #5
chrisn's Avatar
Rewards Points: 232
which for the most part ,don't work
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
molding over molding, Can it be done? jerry1977 Remodeling 3 07-27-2011 02:31 PM
positioning molding joetab24 General DIY Discussions 0 08-11-2010 07:38 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
