Decorative Masonry Foundation - Painting - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 12:19 PM   #1
I have an exterior foundation that is peeling(no primer used) and was wondering if Loxon Primer was a good choice, with Superpaint for the topcoat? I was going to scrape and pressure wash the surface before painting.
Plastik is offline   Reply With Quote
Old 08-20-2011, 01:46 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You are correct. Scrape, wash, make any repairs, apply SW Loxon Primer and apply 2 coats of SW 4uperpaint. We actually use the same products on exterior masonry most of the time. If you want to add a waterproofing barrier then you could use SW Shercrete instead of Superpaint and then there is no primer required.
housepaintingny is offline   Reply With Quote
Old 08-20-2011, 03:15 PM   #3
Should I go with a 1-1/2 inch sleeve?
Old 08-20-2011, 07:45 PM   #4
That depends on the degree of texture. A 1/2 should cover the smoothest of stuccos. You can post a pic for better advice.
Old 08-20-2011, 09:21 PM   #5
The foundation is formed to resemble a brick formation, if that helps.
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 12:27 PM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
Decorative chase for masonry chimney and radon vent? Badfish740 Building & Construction 1 05-03-2010 06:51 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 08:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
