Decks: Staining Versus Sealing? - Painting - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 08:06 PM   #1
Decks: Staining versus Sealing?
Is it necessary to satin or seal pressure treated wood decks. If you do nothing, what are the disadvantages and or advantages?
If you seal or stain, how often do you have to repeat?
rszymko is offline   Reply With Quote
Old 05-28-2012, 07:42 AM   #2
Not sure what you mean by "seal". You can't really seal wood, since it moves with weather changes. Stain gives protection from UV rays and water, with solid stain best. PT wood has a tendency to check, split and warp if left unprotected, but it will not rot for a long time. Depending on the degree and type of treatment, 40 yrs above ground and 20 yrs in ground. Some finish is better than none. With no finish, the deck will become unusable in a short time, or at least ugly.
As to paint or stain, paint puts a layer of chemicals on top of the wood. With expansion/contraction, and weather, this quickly breaks down. Stains actually soak into the surface, and last much longer. Manufacturers claim up to 5-6 yrs with solid stains, but in reality, usually 3-4 yrs is closer. Consumers has done a number of articles on exterior stains, look them up.
Old 05-29-2012, 10:38 AM   #3
I actually used a film-forming, water based stain on mine. It's breathable, so it not only "seals" it but any moisture still is able to get out. I got great results from it.
LeAnnH is offline   Reply With Quote
Old 05-29-2012, 02:25 PM   #4
Too Short? Cut it Again!
Whatever you do, stay away from wax based products like Thompson's.
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (05-29-2012)
Old 05-29-2012, 05:30 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 152
also Behr stain is arguably the worst
Old 05-29-2012, 05:41 PM   #6
Mr. Paint's Avatar
PT wood is already sealed under pressure when you buy it. Put water (A small amount) on it. If it beads up, do nothing; if it soaks in, it would be wise to put a semi-transparent stain on it for protection and beauty.
Mr. Paint is offline   Reply With Quote
Old 05-29-2012, 05:47 PM   #7
Gymschu's Avatar
Rewards Points: 248
Lots of folks do nothing to PT wood. It turns to a weathered grayish brown color so if you can live with that, I would do nothing. On the other hand, PT wood splits/cracks as it dries out and you can limit that somewhat with a quality stain job. It certainly depends on what "look" you want for your deck. I have always had decent luck with Flood clear products. You can buy them off the shelf with cedar, redwood, or clear tones. I also like Deckscapes from Sherwin-Williams.
Gymschu is online now   Reply With Quote
Old 05-29-2012, 07:46 PM   #8
Rewards Points: 150
Not necessary but preferred with an oil stain. Clean it with percarbonate and let dry to 12% moisture content then seal it with a good oil based sealer. You do want a color tint to protect the wood from sun rays for a longer time.
CaptRandy is offline   Reply With Quote
sealing and staining an old bar concrete floor bigvin# Flooring 0 02-15-2012 11:06 AM
Staining large decks rocketdoctor Painting 0 08-19-2010 11:18 AM
Staining vs just sealing preserved wood deck? Hossenfeffer Painting 1 05-28-2010 06:20 PM
Staining Cedar Decks mrbaffy Painting 9 08-18-2009 09:34 AM
staining or sealing a fence mpgumm Painting 2 04-11-2009 09:27 AM
