Decking Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 03:52 PM   #1
Decking paint
Hi there everyone its nice to be here, i am hoping someone could give me the name of a good decking paint. Thank you BJ
bigjohn is offline   Reply With Quote
Old 04-09-2010, 04:01 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Don't use paint, use a "solid stain" for decks
I've been using Ben Moore, Sikkens, and Sherwin Williams for years with success
I've also run across enough failed Behr coated decks to say stay away from that
-It's also a real "bear" to remove the remains (to re-coat with something good)
slickshift is offline   Reply With Quote
Old 04-09-2010, 04:01 PM   #3
slickshift's Avatar
And welcome to the site!
Old 04-09-2010, 04:15 PM   #4
Hi there Slickshift thanks very much for the help i will try and find the item you recommended.
Old 04-09-2010, 04:16 PM   #5
slickshift's Avatar
You're Welcome
Anytime bigjohn!
Old 04-09-2010, 09:04 PM   #6
jce
Cabot's products are also good if you can get them in your area.
jce is offline   Reply With Quote
Old 04-11-2010, 06:59 AM   #7
I used a cabot water based stain on my hot tub surround. It turned out great except it started to peel off. I only used water based stain so I could have a nice light blue color. I am guessing that I didn't have the surface prepped correctly. The wood was redwood. So make sure you get all the info before attempting a big project.
Bushman is offline   Reply With Quote
Old 04-11-2010, 03:11 PM   #8
Thank you all very much
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
