Old 05-05-2012, 11:15 PM   #16
Deck staining problems
The problem with second coating is many times it will sit on top and actually become sticky to the touch.
CaptRandy is offline   Reply With Quote
Old 05-07-2012, 10:20 AM   #17
Originally Posted by pucks101 View Post
That really looks to me like one single coat of not-very-stirred semi-transparent stain on the left, and a 2nd coat of semi-transparent stain on the right. If you like the look of the stain on the right, you could probably re-coat the left so it looks the same. I think once you use this stuff though, you're stuck re-coating it every 2-3 years, because it's going to chip and peel, especially on a flat surface that you walk on..
I think you are confusing semi-trans with solid stain.
Windows is offline   Reply With Quote
Old 05-07-2012, 09:53 PM   #18
Yes- thanks, good catch. I meant to say it looked like poorly stirred semi-transparent on left, and a solid-stain on the right..
pucks101 is offline   Reply With Quote
Old 05-10-2012, 01:38 PM   #19
I actually used Smart Strip and Lifeline Ultra 7 on my front porch and back deck. They were both painted AND somehow had some type of "waxy" coating under the paint which I will never understand. They turned out BEAUTIFUL and I know I used a good product that will last. Both are environmentally friendly too so I didn't kill my flowers and bushes!
LeAnnH is offline   Reply With Quote
Old 05-13-2012, 11:15 AM   #20
Lots of valuable advice! Thanks everyone. I stripped the right side yesterday- used a stain stripper, pressure washer, and then sanded- took all day but for the most part is all off. I am thinking of leaving the other half of the deck the way it is- they are all separate boards- thus even if it does notlook exact, each board will be stained from end to end. At the very least, the part that looked painted on is gone!
grammy76 is offline   Reply With Quote
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
staining a deck and sanding erinherbst Painting 1 07-02-2011 10:48 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
Deck Staining Question Punjabtantrum Painting 8 06-23-2009 11:51 PM
