Old 03-21-2008, 04:53 PM   #1
Default Deck Staining -- compatible primer & stain issue?
Hi,
I'm about to stain a deck and some related garden structures for the first time. They're pressure-treated, 1 year old, have no product on them. My contractor is terribly impressed with Deckscapes new Life Extender. He gave me some to try, and I must say it really did bring out the wood grain. But I don't want to use Sherwin Williams stain since they don't have an oil based one (at least in PA). Can I use the Deckscapes Life Extender and then apply Benjamin Moore oil-based semi-transparent deck stain? Or is it ill advised to mix and match manufacturers' products this way? I can, of course, overrule my contractor and use a BM primer if people think he's making too much of this. They don't seem to push their primers as much, but their website does show two that can be tinted to the approximate shade of the stain.
Any help would be appreciated.
butterclem is offline   Reply With Quote
Old 03-21-2008, 10:21 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
It is ill advised to mix and match manufacturers' products that way
Not so much on some things, but this one, I wouldn't
slickshift is offline   Reply With Quote
More On This Topic
Finishing a deck can seem like an intimidating task with the different products and materials used. However, it doesn't have to be overwhelming when you break everything down into steps and figure out exactly what you need to get the job done. Read More »
Finishing Wood Furniture
Finishing Wood Furniture by Expert Village
After we've got this wood filled and stained, the wood filler has to dry overnight, then you're ready for the next day. But, then we'll start with a sealer, which is a lacquer sealer that we usually get from Sherwin Williams and we'll put several coats... Read More »
Adding a conservatory to an existing home has become a hot commodity amongst home owners. Not only is it a way to increase living space, adding a conservatory can boost the overall value of a home. Before you get started on your project, however, read... Read More »
This is an old deck where the joist were bad and this tongue and groove pine was on the deck which I have not ever seen before. This was totally unacceptable. I took up all of the tongue and groove going across the deck (12X17). The joist were all bad... Read More »
Deck wood should be carefully and properly maintained through the entire year. It should be consistently treated with the best quality cleansing products on the market. Preparing deck wood takes particular skills in order to treat wood properly. Read More »
New deck staining questions sk8z Painting 7 11-14-2007 08:45 PM
Deck Stain Color idea's flyultralite Building & Construction 0 07-11-2007 04:48 PM
Major screw up: Deck stain usaalways General Discussion 4 07-10-2007 04:39 PM
Removing excess deck stain from vinyl siding sleepy23 Remodeling 7 05-16-2007 09:13 AM
staining my patio deck Morry Painting 3 07-26-2006 05:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
