Deck Stain On Vinyl - How To Remove? - Painting - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 02:46 PM   #1
The Big Builder
Deck stain on Vinyl - How to remove?
One of my clients sons was staining their deck and splattered deck stain on the vinyl siding and cant get it off. He tried mineral spirits and goof off but it isn't working.
Does anyone know of something a little stronger that won't reck the 15 year old yellow siding?
Thanks all.
bigbavarian is offline   Reply With Quote
Old 08-26-2011, 04:28 AM   #2
latex or oil based?
torpainter is offline   Reply With Quote
Old 08-26-2011, 05:54 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Sounds like an oil stain. Solvents in the stain actually dissolve their way into the vinyl of the siding. No getting that out if it's so deep that Goof-off doesn't work. Goof-off has xylene in it, which will melt the surface of the siding when using it to try and clean it. If that doesn't get the stain out, you are out of luck.
Darkling Designs
poppameth is offline   Reply With Quote
Old 08-26-2011, 06:40 AM   #4
Gymschu's Avatar
Rewards Points: 846
Poppameth is right. If the Goof-off isn't working.........Now, I usually don't recommend power washing vinyl, but, in this case, you may have to give it a shot. I don't have a lot of confidence that it will work, but, you may be out of options at this point. Test an area to see if you can get the stains off before doing a full-blown PW of the area.
Old 08-26-2011, 07:22 AM   #5
The Big Builder
Thank you all. I guess that is the reason why you don't have your kids do these type of jobs.
Deck Power Washed...now many days of rain before stain! mark2741 Painting 67 09-27-2013 06:32 PM
Solid Color Deck Stain over Prev Painted Deck? s_nguyen Painting 3 05-01-2011 11:21 AM
Staining problems on Cedar deck pomi Painting 6 09-24-2009 02:23 PM
Deck Stain jte1130 General DIY Discussions 1 04-07-2008 02:04 PM
