Old 07-12-2009, 10:52 PM   #1
deck stain or just sealer
what can i use for my deck , what will last longer , stain or sealer thanks . in windsor ontario canada.
robotgib is offline   Reply With Quote
Old 07-16-2009, 04:27 PM   #2
NAV
anything you use is only going to last 2 to 3 years. if you go with just a sealer make sure it is UV resistant. otherwise your wood will turn gray in the first year but still repel the water.
Not familiar with the options you have up in Canada but here are some good deck stains:
SW semi-transparent acrylic
CWF - is good but multiple applications causes a varnish like look
TWP - Excellent product. it is hard to find though. ICI can special order it so you better know the exact quantities you need.
Stay away from Behr products.
NAV is offline   Reply With Quote
Old 07-16-2009, 06:52 PM   #3
paper hanger and painter
chrisn's Avatar
Old 07-16-2009, 07:11 PM   #4
Matthewt1970's Avatar
I always recommend Sikkens. Use the oil based if it is available.
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Spraying a deck stain hdansjr Painting 3 04-22-2009 12:36 AM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 06:51 AM
What is the best way to apply stain to a deck? flashme18 Painting 4 04-24-2008 10:23 PM
Deck Staining -- compatible primer & stain issue? butterclem Painting 1 03-21-2008 09:21 PM
