Deck Sprayer Problems - Painting - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 08:11 AM   #1
Deck sprayer Problems
Hi All,
I bought a pump deck sprayer yesterday to stain my deck and I'm having issues. It came with 3 nozzles fine medium and coarse I have tried all 3 and the semi transparent stain is coming out in foamy streams which I then have to brush?
dieselgirl is offline   Reply With Quote
Old 05-06-2012, 08:22 AM   #2
the Musigician
DangerMouse's Avatar
What brand of stain? Did you thin it? If so, with what?
DM
Old 05-06-2012, 08:50 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Is it possible that you have a defective sprayer that is allowing (pulling-in) air during the spray process?
- Build Well -
Old 05-06-2012, 08:51 AM   #4
it is sico semi transparent deck stain... I didn't thin it am I supposed to?
Old 05-06-2012, 08:56 AM   #5
It seems to be holding it's pressure
Old 05-06-2012, 09:06 AM   #6
the Musigician
What does the container say?
DM
Old 05-06-2012, 09:14 AM   #7
The can doesn't say anything about adding thinner
Old 05-06-2012, 09:19 AM   #8
It also doesn't say anything about using a sprayer. Are there only certain types of stains that can be sprayed?
Old 05-06-2012, 09:21 AM   #9
the Musigician
What brand name stain? What brand/model of sprayer?
DM
Old 05-06-2012, 09:25 AM   #10
sico semi transparent exterior deck stain and chapin clean n seal 2 gal deck sprayer
Old 05-06-2012, 02:07 PM   #11
Gymschu's Avatar
Rewards Points: 248
In 33 years of painting, I have never had any luck using a pump sprayer to do a deck. I'm old fashioned and find that the brush and roller give the best results. They put just the right amount of stain on the deck and the push the stain onto and into the deck so it penetrates like it's supposed to. Doing it this way isn't any more work especially when you consider that all sorts of problems can happen with a pump sprayer.
Gymschu is online now   Reply With Quote
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
DangerMouse (05-06-2012), dieselgirl (05-06-2012)
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 12:26 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 01:53 PM
5/4 x 6 or 2 x 6 PT Decking, what would you choose? Quicksmoke Building & Construction 9 08-23-2011 09:17 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
