Deck Sealer??? - Painting - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 08:18 PM   #1
Rewards Points: 101
Deck Sealer???
Not really a paint question but I wasn't sure which category to place it. Wat are the best choices for a wood deck sealant? Didn't really want to go with any kind of stain. Prefer to keep as close to the natural wood as possible but just want to seal/protect the wood.
jte1130 is offline   Reply With Quote
Old 09-30-2011, 08:12 AM   #2
Gymschu's Avatar
Rewards Points: 668
I like CWF personally. It's reasonably priced and gives you about 2 years of deck protection before recoating. There's hundreds of clear coat products out there & you will get many recommendations, but give CWF-UV a look-see...........it's made by Flood and can be found in most paintstores or Big Box stores such as Lowe's.
Old 09-30-2011, 08:27 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
CWF is good. Make sure you clean the deck well first- use a wood brightener and a stiff brush, then hose off, let dry.
Another product i have used is A-100. It is a paraffin base though, so once you start with that system you need to stick with it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Marbledust (09-30-2011)
Old 09-30-2011, 08:53 AM   #4
Rewards Points: 150
I like Olympic Maximum clear waterproof sealant. It's oil base, and a bit pricey, though.
NancyNGA is offline   Reply With Quote
Old 10-02-2011, 11:55 AM   #5
Rewards Points: 101
Thanks all!! Heading out to Lowes today to see their selection. I will probably go with the CWF if they have it.
Old 12-13-2011, 12:45 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You will need seversl days of warm weather, especially with an oil base product. I like using Sikkens Srd. You wil want to clean the deck first, a sodium percarbonate cleaner is your best bet, as it does not damage the wood and/or landscape. Use a garden hose or pressure washer with low pressure. After cleaning you will need to apply a wood brightner to the deck. Let it dry out well and then apply your sealer/stain. I don't know where you are located, but I personally would not be applying anything to a deck until the late spring.
housepaintingny is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The absolute worst deck sealer award RemodelMan Painting 19 06-18-2008 09:03 PM
