Deck Post Stain High Altitude - Painting - DIY Chatroom Home Improvement Forum
Old 05-09-2011, 09:57 AM   #1
deck post stain high altitude
At 9,000 feet we get strong sun, snow and rain. I have had to replace my deck posts every 5 years as they rot. I have used sikkens and sashco. Neither last more than a year or two.
Has anyone been successful in staining at this altitude? sikkens and sashco peeled.
I was thinking of trying messemers.
amie is offline   Reply With Quote
Old 05-09-2011, 12:51 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
First thing I can think of is wood should not be in contact with soil or concrete. That just makes them wick moisture in and cuts the lifeof the wood in half or more, even pressure treated. If that is not the case and your posts just rot out in 5 years, I think it is time to take the plunge and build it out of man-made products.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 05-12-2011, 04:52 AM   #3
Too Short? Cut it Again!
I think synthetic building materials might be the way to go too. As mentioned, if you use wood posts they need to be pressure or otherwise treated where they come in contact with the soil. 9,000 feet certainly puts you closer to the sun so whatever added UV protection you can get in a stain the better. From what you have said though, it sounds like drying out from the wind is your major issue and I am not sure anything but staining more often is going to help with that if you stick with wood.
How to FIX a leaning Deck Post CJ_cda Building & Construction 14 06-18-2013 12:28 PM
has anyone used this deck stain? mklang Painting 4 08-06-2010 09:55 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 08:55 AM
