Old 06-29-2005, 01:21 PM   #1
Question
deck painting
I have a very weathered timber deck which oozes resin in hot weather (now)
i have given it 2 coats of Ronseal decking sealer but the resin still oozes. Can i paint over the sealer ? What should i use? I want to maintain the original wood colour if possible or make it a lighter colour to reflect the heat.
jane Stewart is offline   Reply With Quote
Old 07-01-2005, 03:16 AM   #2
aka:awesomedell
Send a message via MSN to housedocs
deck painting
What kind of wood is it?
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 07-01-2005, 06:04 AM   #3
deck painting
I really don't know. It's a light colour with lots of knot/eyes in it..not expensive
Old 07-03-2005, 06:21 PM   #4
deck painting
The wood is probably pine. Yes, you can paint over the sealer, the best deck paint I have found thus far is Ben Moores. Their deck paint has been modified with epoxy, and holds up very well.
donb1959 is offline   Reply With Quote
Old 07-04-2005, 06:09 AM   #5
Smile
deck painting
thanks. i'll give it a try.
Old 07-04-2005, 10:34 AM   #6
Paperhanger/painter
ProWallGuy's Avatar
deck painting
I would second that on the Ben Moore.
But I would probably prime it with BIN first.
ProWallGuy
ProWallGuy is offline   Reply With Quote
Old 07-04-2005, 11:07 PM   #7
Contractor
deck painting
I'm not sure what 'epoxy' is anymore. Epoxy used to appy to anything that comes in two parts that needed to be mixed together. Later, epoxy was seperated from polyesters (two part resins). Now I'm seeing epoxy as an air dry product.
Epoxies were originally developed as glues and don't have any problems sticking to most surfaces.
I work for 7 BenMoore stores but not as a painter, you may want to check on the primer. Technically speaking, you shouldn't need any and it could foul things up.
Pro knows his stuff and I'm guessing that he is correct. I'm putting this on my To Do list out of my own curosity.
Teetorbilt is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
deck questions robphelan Carpentry 6 06-25-2006 07:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
