Deck Finish - Repaint - Painting - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 02:35 PM   #1
deck finish - repaint
Bought the home in '08 and never owned a deck. some of the paint on the railings has chipped off, and some on the posts as well.
1. what do you use for this? deck stain with sealant?
2. do you use the same thing for the posts as the railings?
3. and do you need to repaint the posts? the post goes fairly high off the ground, so not sure how i'd even be able to paint it myself.
4. does it matter what color you use because you're painting over it?
Thanks!
junkemail0707 is offline   Reply With Quote
Old 04-07-2011, 02:44 PM   #2
Rewards Points: 5,336
This was painted with a solid stain. Basically a paint. You would need to remove all the loose paint before you did anything. You could try to gently power wash the deck to minimize wood damage. Once you removed all the loose paint, you'd make a determination as to what you could do. If all the paint came off, you could do anything you wanted. If only part of it came off, you would need to put a solid stain back on to cover the deck uniformly.
Ron
Old 04-08-2011, 08:10 AM   #3
You're probably stuck with a solid stain, use a stain, do not paint.
You would use the same material, however you could do a two tone deck.
Unfortunately, if you want uniformity, you will. You can use a ladder or get a mini-roller on a long hande to reach the sections you can't reach from the deck. It's possible to do an entire handrail/spindles from the deck.
Remember, not painting, staining. No, depending on the chosen stain, it may influence the number of coats/coverage though.
Thanks!
Hope that helps.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Leveling a deck denemante Building & Construction 10 08-24-2010 08:11 AM
