Decal Removal Holding Up Paint - Painting - Page 4 - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 08:57 PM   #46
Right on BJ. The larger part of our job involves repairing/preparing walls/trim for paint. Painting is about 20% of what we do. And yes, you, me, + Gymschu = 75+ years alone. I don't think we need advice from GC's, plumbers, or HVAC people about how to do our jobs or advise. Three pages of posts largely dedicated to arguing about generally accepted practices versus tearing out walls to rid them of decals, ridiculous. We could have taught OP how to skim coat in three pages. I'm a true believer in division of labor. Echo, stay in the forum of your trade, and I'll stay in mine.
The Following 3 Users Say Thank You to jsheridan For This Useful Post:
Gymschu (03-27-2013), kwikfishron (03-27-2013), user1007 (03-30-2013)
Old 03-28-2013, 12:53 AM   #47
jho
jho's Avatar
To put it simply, when the OP states in plain English that replacing the drywall is out of the question, whether it's cheaper, faster or easier, they simply don't want or feel the need to take that action on. So, with that said, I think we should explore other avenues than replacing the entire wall, or just come to a consensus that the skim coat would be his best approach to fixing said issue. I for one concur with this option.
jho is offline   Reply With Quote
The Following User Says Thank You to jho For This Useful Post:
jsheridan (03-28-2013)
Old 03-28-2013, 06:14 AM   #48
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
So what am I , chopped liver? I am offended
Old 03-28-2013, 07:39 AM   #49
My humblest of apologies. I was basically going by who was participating in that thread alone. I knew Gymschu was but didn't realize that you had slipped a comment in there as well.
Now we're up to 150 years
Peace!
Old 03-28-2013, 11:15 AM   #50
Rewards Points: 5,974
Can I throw in my $.02 about this. As I put this on the same level as using 1/4" drywall as a cover up. It very seldom works, ends up being more work, and usually causes more problems. And as far as skimming the walls there are several ways to do it and it could be done in a day. Let's be real say 1 day for demo, 1 day to hang the rock(and I think I'm being generous here), with drying times at least 2 days for mud and tape. 1 day to prime and 1st coat, 1 day to second coat, 1 day to re-trim, 1 day to load and take demo materials to the dump. Notice I didn't put the cost in. And this is all because there is a stain on the wall.
Old 03-28-2013, 05:08 PM   #51
chrisn's Avatar
Rewards Points: 128
Peace!
100 will be fine, thank you very much
The Following User Says Thank You to chrisn For This Useful Post:
Old 03-28-2013, 06:17 PM   #52
Sorry, I duplicated the previous post.
Old 03-30-2013, 12:52 AM   #53
Too Short? Cut it Again!
I am just going to suggest some other other solvents to you. Rubber cement thinner, if you can still buy it at an art supply store near you, may work. GooGone, Oops and other such things in liquid or rattle cans usually work well on most adhesives. You can get them at your paint store or a real hardware store. Good old WD-40 works to break down many adhesives but leaves even more a nasty, oily mess than other solvents mentioned. If me? Try the rubber cement thinnner. Seems to me acetone would be a very specific solvent. It evaporates and goes airborne so quickly I cannot believe you are having success with it.
Use any solvents with adequate ventilation. Just a suggestion by the way, if you are working with acetone fumes on a regular basis without like a jet engine fan and windows open? You might want to buy a nice aspirator for $50 or whatever. Killed brain cells do not grow back they say.
You will end up with a scarred wall though so you should read up on how to seal it and skim coat over it with drywall compound. We talk about it here often and it is second nature to many of us. It involves sealing the wall with the proper primer, in your case something like GARDZ comes to mind. Then using a wide drywall knife and thinned drywall mud you fill in and resurface the wall. Then you wet or sand lightly with grit paper. You prime again and should be ready for new paint or paper. Sounds ominous and daunting but you can do it if you want. One of us who has been doing it for too, too long will be but more practiced at what is not rocket science.
Adding more drywall in this situation is not necessary and as stated strikes me as a stupid suggestion too.
The Following User Says Thank You to user1007 For This Useful Post:
ToolSeeker (03-30-2013)
Old 03-30-2013, 05:07 AM   #54
chrisn's Avatar
Rewards Points: 128
The mod police are watching
Old 03-30-2013, 09:50 AM   #55
Yeah well I hope they note I don't whine like a little one about not being included in the years of experience total. And come on Chris, real painters don't brag about hanging pre-pasted wallpaper. Hanging paper is a girly man thing and we all know you sucker your misordering mistakes on us as gift paper! Sold usually by tiny little innocent children.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
