Dealing With Wallpaper Glue On BARE Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 08:29 PM   #1
dealing with wallpaper glue on BARE drywall
Been a while since I posted. I am repainting a bathroom but first I had to remove the wallpeper and old glue. I have removed paper and repainted before so i will skip the basics. My problem is the bastard pervious homeowner never did anything right so why should I expect he would prime drywall before he hung paper. There are some sections in the room that were repaired before the paper went up and he just went over it. Man, that wall paper glue really fuses with the compound and bare drywall. After working on it a little my plan is the following.
1) Scrub off what glue I can with soapy water like a painted wall.
2) let it dry and sand off what more glue I can.
3) guardz
4) skim coat to smooth it out
5) prime and paint.
Any suggested alternate approaches?
beerdog is offline   Reply With Quote
Old 09-22-2012, 03:48 AM   #2
Too Short? Cut it Again!
Might be alternatives but you plan seems sound to me! Just be careful about the soapy water as it may end up leaving a residue too if you do not rinse it. I would use plain warm water to get what glue you can. Then hit it a last time with water and TSP. I don't think the soap is going to help dissolve the glue much. Obviously you want to clean with dilluted bleach if you have any algae or such ilk.
Old 09-22-2012, 04:25 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
It is PASTE and or adhesive, NOT glue, shame on you sd, i will let the original post slide.
This time
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (09-22-2012)
Old 09-22-2012, 04:57 AM   #4
This time
Sorry! I know better.
Old 09-22-2012, 09:25 AM   #5
Sorry about the glue comment.
I normally give it a final rinse clean water. I think I will try TSP this time.
Old 09-22-2012, 11:01 AM   #6
Gymschu's Avatar
Rewards Points: 842
Beerdog, I knew your post was gonna stir up a hornet's nest with Chris. It took me a full year to make the transition from glue to adhesive. That Chris sure is a bulldog!
Old 09-22-2012, 11:42 AM   #7
Rewards Points: 5,974
They make a wall paper adhesive remover it's red or comes in a red spray bottle you can get it at any big box store and most hardware stores. i have had very good luck with it, its just spray let sit and wipe. They also make it in a concentrate that you mix with water, the name on the bottle is DIF, like I say has worked for me in the past. The rest of your plan sounds spot on.
Old 09-22-2012, 04:50 PM   #8
chrisn's Avatar
Rewards Points: 394
I know you do
Old 09-22-2012, 04:53 PM   #9
chrisn's Avatar
Rewards Points: 394
Dif works OK but it is on the toxic side, try Safe and Simple, works much better and is non toxic
http://www.safeandsimple.com/
ToolSeeker (09-27-2012)
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Permanent glue to use for a hole in drywall? VLT General DIY Discussions 11 06-09-2010 02:01 PM
This wallpaper glue is stubborn! proofer Painting 7 03-07-2008 05:53 PM
wallpaper on untreated drywall... rjralston Remodeling 4 09-09-2006 12:13 AM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 05:41 PM
