Damaged Walls - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 10:10 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
damaged walls
I just got done stripping my wallpaper from my walls, some of the wallboard was damaged, so I put some "gardz" wallboard repair on, know I'm doing some joint compound to the holes, and uneven surfaces.
I need a lot of compound touch up,
My question is,
is it a good idea to joint compound the bigger (deeper) spots, and then don't worry about the shallow spots. Then put a coat of primer on the wall, to see how much of the shallow spots fix with primer, then go around a skim coat the rest of the uneven surfaces..then another primer coat???
I just want an easier way to repair all my uneven spots
Barry
Barry J is offline   Reply With Quote
Old 11-25-2011, 11:18 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
Barry- sounds like you primed with Gardz first- Excellent!
That will give you a sound surface to work on.
Use as big a mud blade as will fit in a space- I usually have a 12", 6" and 4" as i do this.
Quickly pole sand or hand sand the surface to knock off any "bits".
Prefill deeper stuff and blade level, and let dry (fans help)
If there is a lot of small damage over much of the surface I will then skim the entire surface- have a work light to the side- you need to be able to see well.
Let dry, sand smooth ( using light again!) and prime again. You could use Gardz, but at this point it is easier to use a pigmented primer to see how you did.
Many good choices- I have been using Z123, or Smart Prime, or other quality primer/sealers.
Look over with light- touch up mud as needed, resand those, spot prime and you should be ready for finish paint.
Good luck!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-25-2011, 11:18 AM   #3
Too Short? Cut it Again!
That will certainly work. You really don't want to count on a primer as a substitute for compound though. Try a nice wide blade and all but deepest gouges should fill in as you pass over them with your skim coat.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 09:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
