Old 06-28-2012, 09:16 AM   #1
cypress house
how to stain out side of the house
Goodgalady is offline   Reply With Quote
Old 06-28-2012, 09:31 AM   #2
Renovations contractor
Bonzai's Avatar
cypress house
Use an exterior stain.
Home Renovations & Repairs
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 06-28-2012, 09:48 AM   #3
cypress house
Do some research on cypress, which is wood with a very high moisture content. Generally when painting it, you need to use an alkyd exterior primer.
Will22 is offline   Reply With Quote
Old 06-28-2012, 10:04 AM   #4
Bonzai's Avatar
cypress house
Except that the OP said "stain" ... Unless of course they meant paint as was rather a vague post
Old 06-28-2012, 01:55 PM   #5
sdsester's Avatar
cypress house
Indeed we should see what the OP wants the end result to end up like.
Something like Benjamin Moore Fresh Start Alkyd (solvent based) is what I have used on antique cedar and cypress siding when restoring it for painting. I power shave, then power scrape and finally sand before that though.
If the OP is planning to stain it then I would have other recommendations and depending on whether it is new or old to a point. Of course of major importance would be whether he/she wanted a semi-transparent or a solid color stain.
Some of you know my sad story about getting the house prepped and primed and having some fool buy it mid-project. All the antique siding went into a dumpster and somebody put vinyl on instead. The historical people went nuts. It looks awful. It substracted at least $10K from the value of the home.
I mention this because a certain someone who continually offers terrible advice will pop up with a comment you should vinyl side your house and never have to paint again. Heaven help you if you do!
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
Mr. Paint (06-28-2012)
Old 06-28-2012, 02:41 PM   #6
creeper's Avatar
cypress house
creeper is online now   Reply With Quote
Old 06-28-2012, 03:23 PM   #7
Architectural Designer
AGWhitehouse's Avatar
cypress house
Hahaha...vinyl is final (fine print disclaimer: for 10-20 years depending on grade, usage, surroundings, baseball hits, weed wacker attacks, uv fading, installation quality, and general owner hatred)
I couldn't resist
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
sdsester (06-28-2012)
Old 06-28-2012, 10:13 PM   #8
sdsester's Avatar
cypress house
Originally Posted by AGWhitehouse View Post
I couldn't resist
Wrapping a house in vinyl is like encasing your precious little poodle in saran wrap.
AGWhitehouse (06-29-2012)
Old 06-29-2012, 01:37 AM   #9
cypress house
Rinse the entire exterior using the water hose to remove sanding dust and dirt. Allow the siding to dry for at least two days.
Amanda22 is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 03:54 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
