-   -   cypress house (http://www.diychatroom.com/f4/cypress-house-148483/)
Goodgalady 06-28-2012 09:16 AM
cypress house
how to stain out side of the house
Bonzai 06-28-2012 09:31 AM
Use an exterior stain.
Will22 06-28-2012 09:48 AM
Do some research on cypress, which is wood with a very high moisture content. Generally when painting it, you need to use an alkyd exterior primer.
Bonzai 06-28-2012 10:04 AM
Except that the OP said "stain" ... Unless of course they meant paint as was rather a vague post ;)
user1007 06-28-2012 01:55 PM
Indeed we should see what the OP wants the end result to end up like.
Something like Benjamin Moore Fresh Start Alkyd (solvent based) is what I have used on antique cedar and cypress siding when restoring it for painting. I power shave, then power scrape and finally sand before that though.
If the OP is planning to stain it then I would have other recommendations and depending on whether it is new or old to a point. Of course of major importance would be whether he/she wanted a semi-transparent or a solid color stain.
Some of you know my sad story about getting the house prepped and primed and having some fool buy it mid-project. All the antique siding went into a dumpster and somebody put vinyl on instead. The historical people went nuts. It looks awful. It substracted at least $10K from the value of the home.
I mention this because a certain someone who continually offers terrible advice will pop up with a comment you should vinyl side your house and never have to paint again. Heaven help you if you do!
creeper 06-28-2012 02:41 PM
AGWhitehouse 06-28-2012 03:23 PM
Hahaha...vinyl is final (fine print disclaimer: for 10-20 years depending on grade, usage, surroundings, baseball hits, weed wacker attacks, uv fading, installation quality, and general owner hatred)
I couldn't resist:whistling2:
user1007 06-28-2012 10:13 PM
:thumbsup::yes::yes::yes:
Wrapping a house in vinyl is like encasing your precious little poodle in saran wrap.
Amanda22 06-29-2012 01:37 AM
Rinse the entire exterior using the water hose to remove sanding dust and dirt. Allow the siding to dry for at least two days.
