Cutting A Wall? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2007, 06:28 AM   #16
Thanks to everyone for their help. The walls in the room look great. I actually only put on one coat of color. I put a second coat on one of the walls, and it doesn't look any different from the one-coaters... Is there a larger reason to apply the second coat?
Also, I will never use painter's tape (aka, blue tape) again! It pulled up chunks of paint from around my windows. I'm not entirely sure how I will fix that...short of just touching up over and around it. My concern is that it will now bubble where it was lifted off the primer...
frankthetoad is offline   Reply With Quote
Old 08-07-2007, 10:01 AM   #17
Touching up flaking areas...
Originally Posted by frankthetoad View Post
Also, I will never use painter's tape (aka, blue tape) again! It pulled up flakes of paint from around my windows. I'm not entirely sure how I will fix that...short of just touching up over and around it. My concern is that it will now bubble where it was lifted off the primer...
Does anyone have a recommendation for touching up these areas? Should I take a razor blade and remove more of the paint until it is at a point where it is sticking to the wall and then touch it up?
Old 08-07-2007, 11:59 AM   #18
Tired, Cold, and Damp
slickshift's Avatar
Yes, though a putty knife will do just fine
The razor might go to far
If it's what you got, it'll be OK just be careful
slickshift is offline   Reply With Quote
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 06:21 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
