Cutting Gloss On Polyurethane - Painting - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 06:42 AM   #1
Cutting gloss on polyurethane
I recently applied satin polyurethane to a door using three coats. It is now a bit glossier than I would like. Any way to cut the gloss back without stripping and recoating?
sparky296 is offline   Reply With Quote
Old 01-31-2009, 07:09 AM   #2
Remodeling Contractor
Wet sand with 1000 grit paper or 1500 grit paper found at an auto supply store. Or at same store or painting store buy a deglosser.. made for just this purpose.
Old 01-31-2009, 08:48 AM   #3
Thanks, I'll try the deglosser since I have some of that on hand already.
Old 01-31-2009, 06:44 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
No need to strip
A coat of less glossy poly (satin/low lustre or flat if available) will dull it down a bit
(de-glossers are made to de-gloss for re-coating for adhesion purposes, not to be used and left as is...which by the way is soft...again for re-coating)
slickshift is offline   Reply With Quote
Old 02-01-2009, 10:25 AM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Originally Posted by slickshift View Post
No need to strip
+1. The Deglosser will leave you with an uneven milky white gloss.
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 09:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 11:00 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Gloss Piano Black wood Aquarium stand advice markus09 Painting 8 02-29-2008 06:27 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
