-   -   Cutting gloss on polyurethane (http://www.diychatroom.com/f4/cutting-gloss-polyurethane-37244/)
sparky296 01-31-2009 05:42 AM
I recently applied satin polyurethane to a door using three coats. It is now a bit glossier than I would like. Any way to cut the gloss back without stripping and recoating?
Bob Mariani 01-31-2009 06:09 AM
Wet sand with 1000 grit paper or 1500 grit paper found at an auto supply store. Or at same store or painting store buy a deglosser.. made for just this purpose.
sparky296 01-31-2009 07:48 AM
Thanks, I'll try the deglosser since I have some of that on hand already.
slickshift 01-31-2009 05:44 PM
No need to strip
A coat of less glossy poly (satin/low lustre or flat if available) will dull it down a bit
(de-glossers are made to de-gloss for re-coating for adhesion purposes, not to be used and left as is...which by the way is soft...again for re-coating)
Matthewt1970 02-01-2009 09:25 AM
Originally Posted by slickshift (Post 222663)
No need to strip
+1. The Deglosser will leave you with an uneven milky white gloss.
