Cutting / Edging Very High Walls - Painting - DIY Chatroom Home Improvement Forum
Old 05-06-2009, 05:10 PM   #1
Question
Cutting / Edging very high walls
Hi I am painting a two story family room and two story foyer (must be about 20-22 ft high). I'm trying to figure out how to best edge aka 'cut in' the top of the wall... without an extension ladder/scaffold
I tried the small edger that Home Depot sells (that has a pole attachment) and found that the paint easily goes on the top plastic tabs by the wheels and hits the ceiling (their normal cheap one w/o the tabs does great normal edging but doesnt have the pole attachment)
I have an old, large edger (maybe 4" x 8") which gives me no marks on the ceiling and is decently consistent (considering I am standing 16 feet away or so), but it is all 1/2" from the ceiling. It's quite visible from a 2nd story walkway.
Help?
PS - I'm new here but definitely tried searching!
leemy is offline   Reply With Quote
Old 05-07-2009, 04:56 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
Help?
Hire a painter?
Old 05-07-2009, 01:55 PM   #3
Drywall contractor
Rewards Points: 1,070
Or rent/buy a ladder or some scaffolding. Only way to do the job properly other than hire a pro....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
edger , edging , painting
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
Drilling into concrete walls klycklama Building & Construction 4 02-09-2009 03:07 PM
foam rollers for walls? 7echo Painting 5 01-19-2009 05:49 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
