Cutting In And Coats Of Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 01:31 PM   #1
Rewards Points: 83
Cutting in and coats of paint?
Do you guys typically cut in a second time when applying your second coat of paint?
Bubbagump is offline   Reply With Quote
Old 12-18-2008, 03:47 PM   #2
RippySkippy's Avatar
I'm not a pro painter by any means so take this for what you're paying for it...
I don't cut in a second time...but rather than saying do it 1 or 2 times...I let the quality of the first cut in dictate whether the coverage was good enough to avoid having to do that god awful task a second time.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 12-18-2008, 04:35 PM   #3
Workaholic's Avatar
Yes i do.
Sean
Workaholic is offline   Reply With Quote
Old 12-18-2008, 06:02 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Absolutely
No question
Even if it (at first) doesn't look like it needs it
After the second roll it may look pretty bad
slickshift is offline   Reply With Quote
Old 12-19-2008, 12:16 AM   #5
General Contractor
Yes, we always cut in the 2nd coat.
jensenconstruction is offline   Reply With Quote
Old 12-19-2008, 06:14 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Yes i do.
Old 12-19-2008, 06:31 AM   #7
There is a reason it is called "Cut & Roll"
mark942 is offline   Reply With Quote
Old 12-19-2008, 01:40 PM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
You basicly have to to keep a uniform surface and to keep it from flashing. Plus 9 times out of 10 it's the cutting in that needs the second coat more than the roll.
Old 12-19-2008, 05:48 PM   #9
SNC
what does flashing mean?
SNC is offline   Reply With Quote
Old 12-19-2008, 07:58 PM   #10
slickshift's Avatar
Flashing is basically un-intentional sheen changes (usually random and blotchy)
Old 12-19-2008, 08:05 PM   #11
SNC
Reading some of these threads I see people saying paint the walls flat.
I have never done so because I was told flat was the hardest to clean.
Ive uses flat on the ceilings egg shell on the walls and semi gloss on the trim.
Should I changes any of this?
Old 12-19-2008, 08:17 PM   #12
slickshift's Avatar
You can use whatever you like
It's your room!
Traditionally, it used to be you would usually find flat on walls and semi- on trim
The past few years eggshell has been much more popular for walls, and satin enamel for trim
With the appearance of "matte" (a washable flat with a teeney bit of sheen) the flat these days is often only found on ceilings
(If you called up a premium painting company and said you wanted flat on the walls, they'd use matte)
So flat on the top, egg on the walls, and semi- on the trim is a pretty popular combo
Old 12-20-2008, 05:53 AM   #13
chrisn's Avatar
Rewards Points: 120
Right and to just add, most top quality paint lines of flat are marketed as "washable"
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
