Cutting In To Baseboards? - Painting - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 08:26 AM   #1
Rewards Points: 179
Cutting in to baseboards?
I searched the forums and lots of questions about "order" of painting my question is the Art of cutting in to baseboards. Do the pros paint the walls first and then cut in on the baseboard? Or do they paint the baseboard with wide stokes and then cut in to the wall?
I guess what i'm asking is, is the magic cutting on the walls or the baseboard? I had a pro do a former house and its amazing how straight the line is on the top of my baseboard. When i do the cutting (either on wall or baseboard) at least every 3 feet i'm too high or too low and it makes the wall look crooked.
what's the magic?
windowguy is offline   Reply With Quote
Old 02-04-2009, 05:47 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The Magic is that they are a Pro, not the sequence of application
Pros will have their own preference, depending on the situation
Though when using all water-based paints, many of today's Pros tend to lean toward trim first, walls last, at least with re-paints
With oils on the trim it's a different story...sometimes...it depends
With new construction, it also can vary (due to other concerns), and may be one then the other than next coat back to the first...etc...
Basic Rule with DIY Re-paints is:
Whatever gets you the best results
If you cut a wall better than trim, by all means do the wall last
slickshift is offline   Reply With Quote
Old 02-04-2009, 06:34 PM   #3
onlinehandyman
Rewards Points: 125
I'm a handyman who does painting, but to get a straight line I always use painters tape. I wonder if the pros can make the line without the tape - sounds like you would really have to be a artist to do that.
onlinehandyman
onlinehandyman is offline   Reply With Quote
Old 02-04-2009, 07:06 PM   #4
Remodeling Contractor
All painters cut in a straight line and never use tape. WE could not afford it. Tape takes longer and will bleed enough to not get a perfect line. Tape costs too much money. And we already spent that on quality paint and a quality brush. Both of which a DIYer seems to not appreciate
Old 02-04-2009, 07:46 PM   #5
Rewards Points: 2,906
If you're having a hard time cutting in, use a small artist's paint brush to do your cutting in to get a near perfect edge.
Then, use a 3 inch roller and a piece of sheet metal to paint up to the baseboard without getting paint on it.
When I do this, I wrap one edge of the sheet metal with painter's masking tape to prevent marking the walls. Also, after a while your masking tape will be all caked up with partially dried paint. You just replace your masking tape and you're good to go again.
Also, don't start with a fully loaded roller right at the sheet metal. Load up your roller, hold the sheet metal in place against the baseboard, and spread the paint up to the sheet metal. There should be enough paint in the roller sleeve to properly cover the wall, but not so much that the paint squeezes under the sheet metal and onto the baseboard.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-05-2009, 06:49 AM   #6
Rewards Points: 179
So Bob,
i know you guys don't use tape, the pros always cut in.. so let whast do you prefer? to cut into the wall, or the base board. ?
i can't figure it out.. if you cut into the wall your straight line is on the wall, if you cut into the baseboard you have to be an expert to balance the brush on that teenie tiny top edge of the board.
i have mucho respect for your guys ability to make that straight line.
Old 02-05-2009, 07:40 AM   #7
I work from the top down. Ceilings, wall, trim and them baseboard. Using a short handle 2" angled brush for cutting in along the trim edges. Keep you body balanced and your shoulders square will help. Feel the flow...not the force.
Old 02-07-2009, 09:59 PM   #8
tape
2080 by 3m. costs about 6.00 a roll. inch and a half. I have been a painter for 15 years and always take the time to tape. Paint the trim first. Allow it about an hour to dry(unless oil is used) tape your trim, cut and roll your walls twice and pull your tape off straight out from your walls slowly. Your lines will be perfect.
DGideon is offline   Reply With Quote
Old 02-08-2009, 07:08 AM   #9
Contractor
cobracdn's Avatar
20 + years here.. I never use tape to achieve a line. For one thing you rarely have perfectly straight lines to tape to. Being a DIY forum though, you very well may want to use tape Base is always the last thing I coat.
Cheers
cobracdn is offline   Reply With Quote
Old 02-08-2009, 09:20 AM   #10
onlinehandyman
Rewards Points: 125
Interesting, well you guys are the pros! As I mentioned I am a handyman not a professional painter. I could see where the tape could get costly and time consuming.
Being a handyman not always but in many places, it is the only way that I can make the lines look right. I give you guys credit, what you do is not as easy as it looks. Also thanks for the info - questions and the ability to share information like this is what makes these boards so valuable.
onlinehandyman
How Best to Paint Baseboards in Carpeted Rooms? biggles99 Painting 22 04-17-2011 06:44 AM
Cutting Baseboards on the Wall?? chefwillymac Carpentry 9 09-18-2008 07:40 AM
Reattaching baseboards? Joony Flooring 7 07-06-2008 08:11 AM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 03:10 PM
