Custom Stain An Seal Of Door Jams And Trim - Painting - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 02:57 PM   #1
custom stain an seal of door jams and trim
I have a customer who is suffering from powder post beetles and needs some trim replaced. He calls it a bleached oak look and said the last guy he used mixed paint and varnish together to get duplicate the look on new pieces. I have not experimented with this yet mostly because upon research I keep seeing "DO NOT MIX TOGETHER" from other posters.
Just looking for a point in the right direction.
custom stain an seal of door jams and trim-img-20120714-00043.jpg   custom stain an seal of door jams and trim-img-20120714-00042.jpg
hammerinhand is offline   Reply With Quote
Old 07-14-2012, 06:02 PM   #2
Remodeling Contractor
Just add a small amount of white oil based paint to the vanish and you will be fine.
Old 07-14-2012, 06:06 PM   #3
i thought that might work just wasn't sure.
Old 07-14-2012, 06:09 PM   #4
just do not use latex paint... this is why some claim to avoid this process
Old 07-14-2012, 06:10 PM   #5
what if i used water based varethane? would i be able to use latex then?
Old 07-14-2012, 06:12 PM   #6
never tried it. But the principle should be the same.... do not mix water and oil
The Following User Says Thank You to Bob Mariani For This Useful Post:
hammerinhand (07-14-2012)
Tags
casing , finish , sealer , stain , trim
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 01:21 AM
custom made door trim amakarevic Carpentry 10 02-23-2012 05:55 PM
stain trim bofore or after install? ponch37300 Painting 4 03-05-2009 06:14 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Should I seal where wood trim meets the brick? megan81 Building & Construction 1 07-01-2008 01:40 PM
